2012 Elantra GLS control arm bolt and nut
Pennsylvania
I need to replace a ball joint and it looks like I'll be doing it by replacing the control arm. The rear inner bolt is seized in the sleeve in the bushing so I am going to get the control arm assembly. Any recommendations for finding the specs on the bolt and purchasing it? The hemanual.org site I use for repair procedures doesn't list it. Thanks
If you are referring to the bolt/but that goes thru the compliance bushing, you need:
Bolt:
54563-3K000
Nut:
62618-17000
