Take a look at this. Installed new Febi lower control arms on my Mercedes 11 months ago because the front hydraulic bushings were in really bad shape causing a steering wheel vibration at around 80-90 kmh. I had a long trip ahead and Febi was the only thing available quickly at the time. I drove around 15,000 km since replacement.
Installation was done correctly, everything tightened to factory spec at ride height. One day, a few weeks after overhauling the front end i hear a big clunking sound on the driver side over a speed bump. This might be related to the bushing failure.
I suspect one of the bushings (the worse one) was not installed tight enough inside the control arm at the factory and turned when i heard the noise and has been working under too much tension ever since.
This is just a theory but to me it makes sense. On one of the picture you can see that both bushings are misaligned. I guess this is one more rant about brand parts and that the lesson is always the same: to keep old original semi worn out parts going as long as possible before replacement because the new part will probably be junk unless it is OE.
If anyone around here is still driving a W210, please do not buy Febi lower control arms!
