I spray a little bit of Liquid Wrench on nuts and bolts that I have no intention of removing anytime soon, just to keep it ready for removal down the road (in the next few years.)
Examples: cv axle nut, where the ball joint meets the knuckle (very rusted,) control arm bolts, outer tie rod nut (rusted,) a few bolts holding the radiator and radiator fan. There's a very badly rusted bolt holding the intake manifold to the engine----it's going to strip anyway but I believe this practice helped me remove it when I needed to replace the intake manifold gasket. I was able to remove the bolt by very lightly tapping a smaller socket onto the stripped bolt (it's a very tight space there, I used a 1/2 inch ratchet to tap it.)
One of the more 'traumatic' things working on cars is being unable to remove a nut or bolt because it has stripped or it's broken: learning how to deal with these situations and making preparations for it, is one of the more painful experiences you have to learn from.
Some other thoughts: I've learned to use ONLY Liquid Wrench (and specifically NOT PB Blaster because it has failed me time and time again which is puzzling since they're both well respected. Maybe I got a bad batch? Whatever, I don't trust it one bit anymore.)
