OVERKILL
$100 Site Donor 2021
Originally Posted By: CATERHAM
I always recommend installing a fully functional oil pressure gauge in any modified engine if the car is not already so equipped.
Becoming familiar with the OP characteristics of your engine is a prerequisite to making an informed engine oil choice as far as an oil's viscosity is concerned.
In particular one should know under what conditions the oil pump go into by-pass mode. Even with the spec' 20wt oil, this will be most of the time at higher rev's until the oil temp's have climbed sufficiently.
As a freind of mine discovered when he installed a S/C on his NSX, oil temp's did not increase that much even during fast steet use. The reason, and this applies to most high performance cars, is that you can't keep the engine on the boil for long enough to start increasing the bulk oil temp's and the second you back off the oil quickly returns to normal.
Running a heavier oil lowers the oil temp's when the oil pump will go into by-pass mode and running an oil two grades heavier than spec' may mean you can never use maximum rev's without going into by-pass. If that's the case, using the heavier oil has become counter-productive.
It is an too common newbie mistake to assume a more powerful engine automatically requires a heavier oil.
My advise is to stick with the spec' oil your running now and establish first for yourself whether you need something heavier for the way you use your car. And be assured that even with the S/C installed, driven normally, even with occational WOT bursts, the spec' oil is perfectly fine.
This same engine, but in BOSS 302 trim making HP in the mid 400's, spec's 5w50 FWIW. And IT has a factory oil cooler
He's not going to damage the engine going to 0w40. But he COULD damage the engine if he runs 0w20/5w20 and is able to push the oil temps beyond the lubricant's ability to protect the engine.
So while I agree that without an oil pressure gauge (and oil temperature gauge) we are all just guessing, choosing to err on the slightly heavier side of things with the 0w40 is far safer (and potentially far less expensive) than erring on the thin side and spinning some con-rod bearings.
