Originally Posted By: The Critic
My friend has a 2009 Fit with the 1.5L four-cylinder. Judging from the used oil analysis results posted, this engine is fairly "easy" on oil.
My friend's Fit is approaching 30,000 miles. She has had two oil changes done-- one at 10k and the other at 20k. The OLM goes about 10,000 miles before it reaches 15%. Both oil changes were done at the local fast lube with Pennzoil or Quaker State 5w20 conventional and a Fram filter.
I checked the oil last night and after 9300 miles, it was still medium brown and only 1/4 qt low.
What do you folks think I should fill it with? I can either fill it with Quaker State 5w20 and a Fram filter (since it is on sale), or I can get Valvoline SynPower 5w-20 since it is on sale as well.
Only go by the monitor IF THE OIL MEETS THE SAME SPEC AS RECOMMENDED BY THE OWNERS MANUAL. If the oil falls short, the monitor won't calculate correctly. Use genuine Honda oil which has additional moly or an oil that exceeds it like a full synthetic in the proper weight.
