2009 Cherokee General 3.7?
central ga
General 3.7 ?
Ok, I'm looking at a 2009 Cherokee 221k with a 3.7 . Owner parked it 18 months ago when he bought a hemi version. Says it had started running on the warm end of the scale but didn't overheat(he would turn the heater on and the temp would drop).He did a hydrocarbon test for head gasket failure which was negative.Whilst he wasn't driving it he replaced the water pump, radiator , thermostat etc. Says it's throwing a code for a temp control sensor. Reports no white smoke, I looked at it while he wasn't home, because he is moving (couldn't crank/drive it)with his permission. Oil is dark gray, no chocolate milk, no sludge on the radiator cap or the filler neck, no sludge in the overflow, system was pressurized when I opened the radiator cap. So all of that looks good. But here's the odd part..
The overflow tank smells odd kinda like an old plastic gas can/jug.
Guy said he has drove several times for 20 -30 minutes and let it idle for 45 minutes after one drive with no issues
I thought with the cooling system replacements he was chasing a failing head gasket but I don't really see any signs of it.
The vehicle is in pretty good shape and I'm tempted (he's came down to a grand for it)but cautious. Any idea why the overflow tank smells like that? I looked online and one of the answers was it's near the charcoal vapor system and can absorb the smell.
Any answers/ suggestions
Thanks
I have the 3.7 in my 05 KJ with 233k on it. I had it in an 09 WK like what you're looking at too. Those cooling items are pretty common failure points. I wouldn't buy it though knowing it was overheating. They don't like that. Plus, speaking from experience, get a V8 one. Be it a 4.7 with a good history or a Hemi one. The 3.7 doesn't scoot a 4500lb vehicle around at all, more power is always welcome. And they all get the same 15 mpg. Plus it sucks not having low range, it was a very very very rare option in 09 and 2010 to have low range with the 3.7.
  • Helpful
Reactions: D60
I love both of my Dakotas with the 4.7L but when we bought a Liberty in 2006 the 3.7L was severely underpowered, even with a manual. Is this a full size Cherokee?
Yes full size, I have a liberty and the engine 3.7 is pretty good for what it is. But looking around for a comfy jeep cheap. I don't mind having to put a little money in one to bring it up to what I want, as long as it's not engine or transmission issues I can work with it.
I had a 3.7 in a 2008. The temp gauge was buffered so it wouldn’t show hot unless it got really hot. Normally silent, it made new noises when towing in the summer. I’m liked it as a daily driver but it didn’t seem particularly robust. I did like how it left more room under the hood for access. Aggressive mpg tuning on the transmission was a disappointment - would have been better in the 3.7 with a regear.
Toss the 3.7 and fab-in a 4.0L I-6.
Problem solved!
Seriously, a 2WD, High Mileage 3.7 Jeep is not a great buy UNLESS it is a great price….if it cheap enough, any vehicle is an okay buy, especially if you are familiar with it.
Problem solved!
Yeah. If it were my money, I would skip this generation. The one before it, and the one after, were better.
The WK chassis flexes a ton, regardless of what they claimed. Alignments were a pain with it. Rear axles had some mfr issues.
The prior generation had Jeep DNA. The WK was more like a lifted Chrysler 300. It was in that regard, a very good daily driver, good handling, practical vehicle in stock form.
But, the WK2 was a large generational improvement, and the WJ before still had Jeep DNA. A WJ with a 4.0 was a long-lived and comfortable vehicle that was capable. The only issue I had with the WJ was that I have a long back and short legs, and found myself waaaay too tall in the seat, looking down at the dash and hood from the sun visors like it was a little tikes pedal car.
