Originally Posted By: XS650
Properly done electronics and electric motors aren't a limitation. Present day car CVTs are.
Limitation 1: cost
Limitation 2: weight
Limitation 3: battery life
Limitation 4: space
Why would you want to add so many parts when all you need is a 5-6 speed auto. Why would you need more than a well designed 4 speed? Having 5-6 speed is good enough to keep the engine in a good power band for power and low rpm for efficiency. Variable valve time of all sort (VTEC, VVTi, etc) are widening the power band with good results and reliability, the need for CVT is much lower now.
Limitation 1: cost
Limitation 4: space
