Think this is a 5.3l , but not 100% sure . About 230,000 on the clock and original engine .
This is the company truck I have been driving about 6 months . No idea how often the oil was changed before that . I have been taking it to the fast oul change place about every 3000 miles . 5-w-30 conventional oil & who knows what filter .
I have noticed when I first start it in the AM , if the temp is below about 30F , it has a slight tick , tick , tick . Sounds to me like valves / lifters . Best I remember , a rod knock sounds more " hollow " . But it has been years since I dealt with a rod knock .
Spoke with one of the guys I work with that is car / truck literate . He suggested try heavier / thicker oil . Went to the fast oil change place and asked for 10W-40 . They only had 4 quarts & wanted to know if 10w30 would be OK . I told him use the 4 quarts of 10-40 and 2 quarts of 10w30 . He said it was not good to mix oil ( both oils were the same brand , as far as I know ) . I said , they both come from the same refinery .
Well , he said they would do it . What they put in , I do not know .
I figured it would mix fine & give something like 10W-36 , approximately .
What say yea , was I off base ?
Started it up this morning & could detect no change . Sounded fine this last summer and sounds fine after it warms up .
Told my boss , as old as it is & that many miles . I said , if it was mine , I would not think it would be worth replacing / overhauling the engine . At that age , little chance of finding a good , low mileage engine at a salvage yard .
I recommended driving it until it lays down and dies . Then get rid of it . He agreed .
Thanks ,
Thanks ,
