Haven't logged in in a long time, so hopefully I attached the report correctly. I was concerned about some coolant loss with no visible leak found.
This truck has the Castech heads known for cracking. I did change the radiator cap and haven't seen any loss since, but it's still early.
I did pressure tests with a loss of 1 PSI per hour so could be a leak or the tool I have.
Cliff notes:
Truck is a 2006 2WD LT 4.8. 99,500 on the ODO. Peak 5w30 conventional (got from NAPA when it was .99 cents per bottle!). Now I have 5w30 Maxlife Blend in it and will run that for 6 months, then retest.
Copper is typically high in these trucks but was surprised to see it still high after 99k miles. Figured the engine should be broken in by now.
Please give me your feedback if you have any.
Thanks and take care,
Mike
Cliff notes:
Mike
![[Linked Image] [Linked Image]](https://www.bobistheoilguy.com/forums/attachments/usergals/2019/12/full-28155-38884-report.jpg)
