My first UOA/second oil change (first DIY!) on my beloved W8 wagon since buying. A few notes.:
This car has a flippin' 9 qt capacity and as such, that's 2x bottles of Ceratec. This is a bit more moly/boron that I saw with 1 bottle in my 6 qt Golf. Nice single digit metals - check. Flashpoint/drop in viscosity - seems that all my VWs do it even the non-turbo ones! That SiO2. I had several repairs done including my oil pan which has a ton of sealer and is the most likely contributor here as BS noted (I didn't tell them I did that). In the end, this thing is the hottest under-hood temp car I've owned, it's unreal and the open K&N I rigged on there for noise/looks ended up not fitting as well as I would have liked plus the heat shield I wanted to fab never happened so I put the closed/OE intake back on with a drop-in K&N panel filter. Nobody makes a proper after-market intake for this thing. I run K&Ns in all my cars and all have v. low/single digit SiO2 numbers including the open intake on my Sportwagen. I'll see how it looks next change - I don't think this was a filtration issue. The current fill that replaced this was 8 qts of the same LM LLHT 5W40 with 2 cans of MoS2 and 2 cans of Motor Oil Saver. Also used 2 cans of their Engine Flush prior to the change (but I pulled this sample before). Yeah, I'm a LM fanboi/additive whore..hahahaha
