Yeah, the intake manifold isn't even made of metal on this engine. No need for coolant to go through it.
Can we see a picture IN the oil fill hole?
I think it does have a PCV valve.quote:
Originally posted by brianl703:
The Ecotec doesn't have a PCV valve. It has an orifice built into the valve cover which serves that purpose.
I'm 99.99% sure that the intake manifold on this engine has no coolant going through it.
Just what I was thinking. This problem, by the way, is the reason that I open my oil filler every time I check the oil. I examine inside carefully, with a flashlight. Mechanical defect related sludge will never have a chance to sneak up on me (knock on wood...). I'll be off for diagnostic work at the slightest sign of discoloration.quote:
The head gasket is the other place where coolant can get into the oil. And I guarantee you this engine has a head gasket.quote:
I don't believe it completely, I'm pretty my 9-5 would still rape it's oil if it had a 5 quart sump instead 4.quote:
Originally posted by BrianWC:
Raven, you should know this! Cars w/ more oil volume usually go easier on the oil.quote:
Originally posted by Raven18940:
What does a 5 quart sump have to do with sludge?quote:
Originally posted by The Critic:
1) The Ecotec is NOT a sludge-prone engine. It's one of the few 4-cyl engines having a 5 qt sump. It is quite easy on oil.
Yeah, we all know the basic flaws in the design of the saab, but more oil would allow a little more reserve as far as oxidation fighting, heat disapation etc.quote:
I wonder if they changed it with transmission fluid by mistake?quote:
Originally posted by jazisded:
Well, I pulled the breather hose coming out of the valve cover and it was very clean inside, so I don't think that is the problem. Thanks brianl703.
BlazerLT: What first set me off was the deep red color of the oil on the dipstick. Didn't look normal to me, so I still think there is a problem. Your advise is sound - I will pull the valve cover when time permits. Perhaps next weekend.
Hopefully, we'll get the oil changed Mon or Tues and send the sample off to Blackstone for analysis. Do you all think I should have a Dyson analysis done?
I also did confirm that this is a dexcool car. My girlfriend does not ever remember having coolant added, and it is at the full line on the reservior.
My mom has a 2004 Malibu Classic with the Ecotec. Her drive to work and back is 8 miles round trip. On average she drives 150 miles a week. But I haven't seen anything like this in it when I change the oil, which I do about every 4 months with the Exxon Superflo 5W-30 I got on rebate.quote:
38,000 miles on a 2003 model year vehicle raises the possibility of the vehicle being used primarily for shorter, city trips.
