Remember that my low gearing is skewing my oil temps down a little compared to the "average bear." It's not a huge amount, hence my desire to compare notes with other owners.
The thread seems thoroughly hijacked, so I'll risk listing the gauges:
Oil pressure, coolant temp, rear axle oil temp, trans oil temp, exhaust pyrometer, fuel pressure, exhaust backpressure, volts, and ambient air temp (measured at air filter element intake).
The Gryphon programmer can read things like engine oil temp, engine load, ignition timing, camshaft timing, rpm, instant fuel economy, average fuel economy, trans temp, trans torque, throttle position, cylinder head temp, etc.... a whole bunch more stuff. You can set it to show four readouts and I usually have it set to rpm, instant fuel economy, engine oil temp and percent load (sometimes timing or camshaft timing). It also has three tune levels (four if you include stock), with tuning options for each to control shift points and firmenss, timing, fuel at WOT, redline rpm, top speed, as well as set the speedo to calibrate for gearing or tire changes. Great tool for someone who tinkers.
Hope the post patrol doesn't bust me here for being too far off topic for too long
