Originally Posted by DoubleWasp
There are only three problems people ever have with lifting a WJ:
1. Going too high with the wrong components
2. Wanting a "cheap" lift.
3. Expecting old tired parts will hold up with a lift.
When lifting an old truck, any wearable component needs to be upgraded or replaced.
When I did my 3" lift, I went with 5100 shocks, long arms, full length springs (no spacers) DC front driveshaft, Bilstein stabilizer, JKS heavy duty track bar, stabilizer links, drop pitman, and drop track bar mount, and Johnny Joints with oversized bolts.
A lot of people cried, "Overkill!" when I did mine, because most people literally just toss in spacers and shrug.
When I first drove my truck after getting the alignment done, first thing I did was hit a bunch of potholes and "road features". Not a hint of death wobble. Hit the highway and got her up to 90mph. No weird vibes, steering, anything. Handling? She slices a corner WAY better than stock.
Forget how many miles since I did that. Still complimented by other WJ owners as the "best lifted WJ" they ever rode in.
Hmmmm long arms with a 3" lift? We need you on JeepForum. We have had many discussion's on LA with 3" lift. I think with a 3" lift adjustable short arms are fine. It's over that where you really want long arms.
Put me in the camp that I thought I just needed spacers and shocks hahaha. You described me to a 'T'. I went to install my 2.5" spacers and the coil spring towers in the front were so rusted out, they came out with the springs
. So I had to order new spring perches.
Then I needed to replace all 8 coil spring isolators.
Then I tried to go with the cheap shock route until they blew in a year. So I had to get 5100s.
Then I needed 3-4" zone rear sway bar links.
Then my rzeppa joint went kaboom a year later
I still have the stock trackbar. It has been fine and I've just dealt with having an off-center axle. I was researching hard in the adjustable trackbars and came down to Zone Offroad's and JKS. The problem I was reading was that zone off-road said that my lift height isn't enough for theirs and so it could hit my diff.And then I've been reading JKS had some bad QA with their bushings on their adjustable trackbars.
