$20 budget oil choice.
Me I like high miles version, it made me feel better lol
Then I recommend Quaker State High Mileage Full Synthetic, which is good and costs $20 for 5 qts. I think it lubricates better than Maxlife Blend and costs the same. Unless your car is an oil leaker, in which case Maxlife Blend is better for resucing leaking, in my experience.
You could also consider Supertech High Mileage (synthetic) oil, which is good and around $20 for 5 qts.
You can't make any relative quality conclusions based on this video. 3 rips on the dyno and a $30 used oil analysis means nothing. Just entertainment.
I agree. One time oil use cannot give you real results.
However, he called it durability test and was using a timer, but I didn't get how long he was running the different oils.
It reminds me of people who run a tank oil/gas in a 2-stroke engine and then open the cylinder and say - "The engine doesn't have any visible damage. I don't see or feel any scratches on the cylinder's wall."
I'm going with FVP full synthetic and a Purolator One on the Jeep. I was hoping for a red can but they didn't have one.
5 quarts of oil is $18.97 and the filter is $7.99. Both qualify for the 11% discount. I've found better deals but needing to do an oil change while the boys home i can't complain.
Who has a tribology degree/certification and years of experience working with motor oil engineers and technicians in the motor oil industry, you or Lakespeed?
That's just an appeal to authority fallacy. It's a legitimate criticism and has been discussed extensively here.
Fvp is made by Amalie you can get super tech for $18.64. I would have to say warren and Amalie are nearly identical oils.
Any idea for this promotion if you can submit two separate receipts?
I bought one 5qt already, if I can qualify for the rebate I'll buy another for net ~$10
Yes. You can do the 2 jugs on on receipt. I did it 6 weeks ago....got the rebates in under 1 month. However the stupid $10 rebates are electronic and require you to provide more personal information on line to QS just to use them. I decided that wasn't worth it. So I have $20 in rebates that will expire.
Valvoline maxlife synblend
super tech full synthetic 20k miles
Quaker state synthetic
Which one would you choose. I had 4 family vehicles I will do oil change to . They all use 5w30. My oil filter choice properly fram orange can. Or STP blue oil filter. 5k or 6 month oil change .
Super Tech is a quality oil. Don't let the sheep have you spend more money than necessary. The most important thing is clean, fresh oil. There is no super oil. Just super advertising.
Very commonly repeated mantra here that isn't always true. It is very engine and application dependent. See these posts here and here. When oil is fresh, the lighter ends burn off first. So using lower quality oil and changing more frequently can actually increase deposit formation compared to using a higher quality oil even if changed less frequently.
I know it’s hard to swallow NAPA full synthetic gives the big coin stuff a run for its money. 🤑
I think NAPA Synthetic is the same oil as Valvoline Extended Protection Full Synthetic. That was moderately expensive until recently. It's now regular price $26 for 5 quart jug at Walmart. Last time I looked, NAPA Synthetic was $29 for 5 quart jug.
So NAPA Synthetic isn't a low cost oil. Never has been. I don't know why Lakespeed thinks it's low cost.
I think you're projecting your own appeal to authority fallacy onto these oils in your assumption that expensive big name oils are automatically better.
You make me tired. You're screen name is well chosen. Kudos on that. 👏
Hmmm why do you think that criticizing a test method is automatic praise for "expensive big name oils"? I think more than likely you are offended that a "test"/Youtube video which confirms your bias received some criticism for its methodology.
Here and here I am praising Quaker State Euro which sells for $23 every day. Is that an "expensive big name oil"?
Not sure what your deal is right now. Hope you have a better day.
I did not have a preconceived bias about NAPA oil. I had no opinion about NAPA oil at all. I also have no reason to doubt Lakesspeed's video.
It wasn't until after I watched that video that I researched NAPA Synthetic oil's specs and learned that it (appears to be) the same oil as Valvoline Extended Protection Full Synthetic. If it had the Valvoline Extended Protection Full Synthetic label on the jug, which is a big name oil, would you have the same opinions/assumptions?
Also, if you have no respect for Lakespeeds trilbology education, certification, and decades of job experience, then lets apply that thinking to other professions to show the absurdity of your "authority fallacy" idea/attitude.
If you're a passenger on a plane, do you want the pilot to have training, experience, and a pilot's license? Or is respecting those things just authority fallacy? Should we just let any random passenger blowhard with enough unfounded confidence/narcissism try their hand at flying the plane? Would you want to be a passenger on that plane?
If you're a patient undergoing surgery, do you want the doctor to have training, experience, and a medical license? Or is respecting those things just authority fallacy? Should we let anyone who claims to know what they're doing do surgery on a patient? Would you want to be that patient?
You're advocating perpetuating the democratization of knowledge, which means any overconfident schmuck off the street that has an opinion would be considered equally qualified in a specialized field as a certified expert in that field just because the schmuck says so.
So yes, I have a problem with that. The man is certified in tribology and has decades of job experience in that field. I respect that.
I doubt any oil company (or piston ring company) would hire you to do what he does.
They wouldn't hire me to do it either because I'm not qualified. The difference between you and I is that I know I'm not qualified to do his job, and I know enough to respect that he is qualified, certified, and experienced.
