$2 VS. $12> OPINIONS!
I've come to the conclusion that a $12 filter isn't $9 better than a $3 filter. It's Motorcrafts for my Fords and AC's for my Chevy van, especially since the local NAPA store moved.
quote:
Wal Mart Super Tech oil filter! I think it's a Bosch. At a...$1.97!
Uh, that would be because the Bosch USA aftermarket filters are made by Champion Labs, which also makes the WalMart filters and many of the AC-Delcos.
Personally I'm buying Baldwin or Wix filters these days.
John
I just buy Baldwin filters in discount quantities and otherwise "fuhgeddaboutit". At least I know who makes it and know that it is quite good.
You probably can't go wrong with either end of the price range as long as you change your oil & filter according to the mfg. specifications. I feel better using a OEM filter or a so called premium made filter.
quote:
Originally posted by T-Keith:
IMO, the Supertech filter is a better deal. I wouldn't buy a M1 or K&N filter simply on price. All three are made by Champion Labs. For filtration I'd pick the Pure One, for flow I'd use the Regular Purolator, and for a comprimise I use the AC Delco. All are under $5.
-T
T-Keith: And which for the most reliable by-pass valve?
Joe
The way I feel about it is if you have 3000 oci, then go with a Purolator Plus, AC Delco or Wal-mart ST. If you are using Synthetic oil and 6-8K oci's, then go with the PureOne, Wix, or NAPA Gold.
The filters I cut apart did not have a bypass valve, nor do any filter I use. IMO an engine mounted bypass valve is best.
-T
quote:
What Baldwin filter do you run? Does it appear the same as in the thread "Baldwin B31 defect?".
Bob W.
quote:
Joe
I very much prefer the Wix-style bypass valve at the threaded end of the filter. Less chance of washing any crap back into the engine.
IMO, $12.00 for a filter is crazy unless you've got specialized racing application. Plenty of excellent, moderate cost options; Motorcraft, Wix, Hastings, Purolator, et all.
The way to tell how good the filters are would be a particle anaylsis . The synthetic media's forte is long life . Bob's oil filter and Grease's are part of the picture. Which is the best filter is like which is the best oil or the syn vs, petro oil.When I think i got it down, Some new tidbit of information comes along and I am back to square one.
