AC Delco filters
Originally Posted By: 05Blazer
Steve20
The Yukon XL with AWD coms with the 6.0L. Also my 5.3L still has the iron block!
The pickup truck 5.3L have the Aluminum block. Glad to hear you don't have any engine noise troubles. I know some that do on their trucks. If I can get regular non-ecore PF48s I will stick with those. Otherwise it will be Mobil 1, K&N, or Royal Purple at 2OCI intervals for me.
No. All Yukons and Yukon XL's come with the 5.3. The Yukon DENALI versions have the 6.2. Only the 3/4 ton Yukon XL has the 6.0L.
All Tahoes and Suburbans have the 5.3. Only 3/4 ton Suburban gets the 6.0L
All Escalades get the 6.2 and all Hybrid (Tahoe/Yukon/Escalade) get a special 6.0L.
ALSO - depending on how your SUV is equipped you will get the iron or alum block engine. We put both in them..same with pickups.
** I am referring to 2007-2013 models but the same is true for prior models except the 6.2 was a 6.0 then and the 4.8 was available too.
I've posted before about AC Delcos. I stopped using them after 2 failures. No more Delcos for me. Been 3 years since those 2 failures and every filter BEFORE and AFTER the delcos have performed flawlessly.
Sounds like you got some e-core versions!
I never thought at the time to check. Here is the short version...Towing RV in a trip, 1500 miles on oil change. Pull off the highway for gas. Start up the truck and ZERO oil pressure. I shut off the truck right away. Start it again..ZERO oil pressure. I rev the engine and bam - oil pressure. This than happens at every stop where reving the engine gets pressure up. Almost like a bad relief valve or something. I get to the campground, unhitch and drive to an auto parts shop. Grab a random Bosch filter and instantly - NO more issues the entire trip and oil change interval. Next oil change I use another bosch and no issues. Following oil change, another AC Delco and within 2000 miles...SAME ISSUE!!! I immediately replace the filter with an STP and issue gone. Now, a few years later and never using an AC filter again, I've never had the issue again.
