The high NOx makes me think the EGR is not working.
What's the objective? Clear out some carbon buildup that may or may not be present in the combustion chamber? This will not burn off any carbon that is there. Also, this is failing due to some mechanical failure, not carbon build up that an "Italian tune-up" will fix.
No Colorado got rid of the 25 year "classic vehicle" plates a few years ago. Not sure who or why they did this.Why is on board diagnostics N/A?
I think they did this test wrong, no?
If you already had a set did you have to buy new ones?No Colorado got rid of the 25 year "classic vehicle" plates a few years ago. Not sure who or why they did this.
Probably because people were registering 25 year old Civics and F150s as classics to avoid inspection and using them as beaters,No Colorado got rid of the 25 year "classic vehicle" plates a few years ago. Not sure who or why they did this.
No i considered going this route as I hardly ever drive it. The struts are bad, it needs a head gasket and i bought a radiator for it as the radiator has a small leak.If you already had a set did you have to buy new ones?
I was referring it to being an OBD2 car. Mandated in 1996. Why are they using a tailpipe sniffer?No Colorado got rid of the 25 year "classic vehicle" plates a few years ago. Not sure who or why they did this.
Colorado is in bed with the epa and testing procedures. Apparently there is a 7ish year exemption on new vehicle emissions then the next 10 years I think are obd2 plug in after that they are all tailpipe tested. I wish Colorado would just do away with emissions testing for good.I was referring it to being an OBD2 car. Mandated in 1996. Why are they using a tailpipe sniffer?
Probably because of people gaming the system. Resetting the check engine light, then driving it until the required number of monitors have been set but before the check engine comes back on and getting it inspected.Why are they using a tailpipe sniffer?
I could do that with any OBD2 vehicle regardless of year.Probably because of people gaming the system. Resetting the check engine light, then driving it until the required number of monitors have been set but before the check engine comes back on and getting it inspected.
I'd say just the opposite. With OBD2 you can monitor the emissions system and see when its ready to pass. On a sniff test, you have no idea unless it's so obvious when it won't pass.Its much easier to cheat a sniffer than OBD2.
Get the engine fully up to temperature and clean the spark plugs, as max power is max heat, pressure and airflow through the intake, heads and exhaust.What's the objective? Clear out some carbon buildup that may or may not be present in the combustion chamber? This will not burn off any carbon that is there. Also, this is failing due to some mechanical failure, not carbon build up that an "Italian tune-up" will fix.
I'm going to replace the spark plugs change the oil and maybe throw in a bottle of "guaranteed to pass" and see if that does the trick.Get the engine fully up to temperature and clean the spark plugs, as max power is max heat, pressure and airflow through the intake, heads and exhaust.
Doesn't everybody do this? It's perfectly legal.Probably because of people gaming the system. Resetting the check engine light, then driving it until the required number of monitors have been set but before the check engine comes back on and getting it inspected.
I've got a 2000 with the 2.2 sitting here right now. It's only got about 157k, though.Today I learned that there is a 1997 Cavalier still on the road.
Yes legal but was responding to the comment that sniff tests are easier to circumvent than the obd2 test.Doesn't everybody do this? It's perfectly legal.
