Originally Posted By: Anduril
That poor engine... flooring it without even warming it up first? Looks like yours had the 3 speed auto, which is absolutely horrible for both acceleration and MPG. I made sure I got one with the 4 speed and remember getting a personal best of 37 mpg doing 400 miles of straight freeway at 70-80 mph. Doesn't sound bad for a 4-cylinder with a pair of Magnaflows behind it, especially compared to a similar Honda.
I swapped out my gause cluster with one from a Sunfire, because I like the layout better along with the red backlighting. Swapped the HVAC controls and gear indicator to match. Paint is holding up ok except for the c-pillars and both bumpers which have been replaced. I might do a DIY repaint on those, as I do actually like the body style (sort of a baby Camaro of the same vintage, imo). Perhaps a red racing stripe (yes, I know...) to match the interior.
Oh I floored that thing everywhere, anytime, and for any reason. The gas pedal might as well have been a ON/OFF switch.
And yeah, the 3 speed. That engine did quite a bit of running at 4500ish rpm for hours on end through the Nevada desert since there was no OD. First time I did that was when I discovered it would slurp Mobil 1 5W30 faster than 1qt/1k mi while running like that.
