Originally Posted By: artificialist
Originally Posted By: StevieC
Older Engines with Flat-Tappet Cams need higher ZDDP. They have reduced the level of ZDDP in modern day oils to prevent damage to the Catalytic converters. In your car you shouldn't have one, so you could up the ZDDP with an additive. The amount of miles you drive per oil change (1,000/yr) wouldn't warrant it though and I wouldn't worry about it...
If that were 100% true, the Jeep 4.0L engines would have been extinct by now.
Read it on this board for yourself. It has been reduced and does affect these style engines. (Parisienne included). The only real difference is with the reduction of ZDDP in modern day oils, engines such as these can't run the oil as long as a car that isn't equipped with Flat-Tappet Cams.
