Your Dodge will be fine on just about anything you out in it. Low compression, low cam lift, low RPM means you don’t need any special oil or extra ZDDP. Any modern oil will do. I would lean towards an oil related for diesel because of the extra additives for suspending soot and dirt.
If the history is unknown, I would run some short OCIs. Very short. 500 miles. Keep an eye on the oil condition.
Some of these old engines have a tremendous amount of sludge from running non-detergent oil in the past. A lot of old wives’ tales in the old car community about keeping them on a diet of non detergent oil means that it might be pretty dirty inside, and your modern oil will start cleaning it up.
If it were mine, I would drop the oil pan to clean it up and see how the engine looks inside. That would guide my oil change regimen. It may have had an informed owner, been run on modern oil for a while, and be nice and clean.
Or, it may not...
The only real issue with an old flat head in modern days is the lack of lead in the gasoline. The valve seats in these were soft. The lead in the gasoline “back in the day” helped prevent valve seat wear. No lead means that they can wear the valve seats pretty quickly under high speed/high load operation.
Don’t run it hard, or perhaps look for a “lead substitute” that was marketed to protect the valve seats.
Cool truck. Pics when you get a chance!
