REMEMBER THAT THIS IS A 15,000 MILE RUN ON CONVENTIONAL OIL!
Oil: Motorcraft 10W30 HDEO
Vehicle: 2005 Ford F150HD, 5.4L V8
Notes: Experimental run where the oil was run 5K, tested including a particle count, then a 3 um bypass filtration system was installed. The oil was tested again at 10K, including a particle count. Then the oil was changed at 15,496 and tested again, including a particle count. I had two UOAs done on the final oil sample at two labs, ANA Labs and Blackstone, just to compare the results on the same samples taken at the same time. That is what I will show here, the last UOAs and the (optical) particle count. The same P1 filter was use throughout the 15K run. As soon as I get a simple text program for my Mac that will work with the code boxes here (none of the ones I have will, and I end up having to spend a lot of formatting time), I will make up a chart with the 5K, 10K and 15K info.
I will tell you this; the ISO code for the virgin oil was 20/19/16. The ISO code for the 15K oil was 20/18/14 so the 15K oil with the bypass installed was actually CLEANER than the virgin oil (both the code and the actual counts since the code represent an range of counts... each code is an approximate 50% change in counts from the one above or below). The ISO code after 5221 miles without the bypass was 24/22/16, so you will note that the oil was significantly cleaned up from that state. FYI, the PC at 10K miles was exactly the same as the 15K.
Code:
Miles on Oil: 15,496
Miles on Vehicle, 44,785
Makeup Oil: 2 qts (Added when bypass installed at around 5K miles)
Particle Count ISO 4406
>4um: 5419
>6um: 1632
>14um: 148
ISO Code 20/18/14
Bstone ANA
cSt @ 212ºF 10.40 11.02
TBN 1.9 2.6
TAN 4.4 NA
ALUMINUM 4 5
CHROMIUM 1 2
IRON 28 29
COPPER 5 6
LEAD 1 1
TIN 2 0
MOLYBDENUM 12 11
NICKEL 1 1
BORON 6 3
SILICON 15 21
SODIUM 2 3
CALCIUM 2033 1557
MAGNESIUM 76 81
PHOSPHORUS 1002 1027
ZINC 1185 1183
cSt Visc @ 100c 1185 1183
INSOLUBLES 0.2 0.2
WATER 0 0
FLASHPOINT ºF 380 NA
FUEL 0 0
Code:
>4um: 5419
>6um: 1632
>14um: 148
ISO Code 20/18/14
Bstone ANA
TBN 1.9 2.6
TAN 4.4 NA
ALUMINUM 4 5
CHROMIUM 1 2
IRON 28 29
COPPER 5 6
LEAD 1 1
TIN 2 0
MOLYBDENUM 12 11
NICKEL 1 1
BORON 6 3
SILICON 15 21
SODIUM 2 3
CALCIUM 2033 1557
MAGNESIUM 76 81
ZINC 1185 1183
INSOLUBLES 0.2 0.2
WATER 0 0
FUEL 0 0
