ST 5w30 & VPB Restore 10w30, 6K oci, 07 Toy FJ Cruiser w/232k, 4.0L gasoline V6
San Antonio,TX & Leadville, CO
Oil = 4.5 qts SuperTech 10k 5w30 mixed w/2 qts VPB "Restore",
OCI = 18 mths & 6900 miles
Full flow filter = OG Fram Ultra XG8A, C&P and posted a few days ago in the oil filter area.
Bypass filter = Amsoil EaBP90 (2nd run)
Air Filter = Fram XGA9683 (2nd run)
PCV changed @ 197K miles
Vehicle 2007 Toyota FJ Cruiser w/gasoline 4.0L V6 1GR-FE w/VVTi w/232k miles.
My daily driver since 2009. My use of this vehicle has changed in the last 2 yrs. It gets driven now only about twice a week, rarely roaming more than 8 miles from home.
I have always run regular unleaded (Toyota recommends premium).
It does NOT consume any oil and has never thrown a code. Great low mx vehicle.
Looks like it is getting a little fuel dilution, GC=2.2, and viscosity thinned from 11.1 virgin viscosity of this mix, probably due to the short trips. I sampled it earlier than ever, and changed it now, which is earlier than ever.
Virgin oxidation is 45 and nitration is 6, so that's not a problem.
IN with VR&P 5w30 and a Purolator Boss PBL30001.
Didn't change the air filter.
Drained the bypass filter and reinstalled for a 3rd run.
What say you?
Is Si an additive in the Blue Restore? My opinion is the viscosity held up well & you're most likely seeing a "Lower" number since it didn't have many miles & the other samples did which allowed it to thicken up a bit. I think everything is how it should be. We know the high oxidation is from the Blue Restore. A slight bit of Pb & Sn the last few samples so it's getting a bit more wear in those areas. Seeing the miles on this cruiser & little to no oil consumption speaks for itself. No reason to change your plans with it.
@fantastic
Si is 10 in the virgin mix of these 2 oils
Samples #1 thru #14 were various oils.
Sample #15 is the only time I used this mix.
Sample#1 - Dec 2010 = Amsoil SS 0w30 - 17,000 miles
Sample#2 - Dec 2011 = Amsoil SS 0w30 - 18,700 miles
Sample#3 - Aug 2012 = Amsoil AMO 10w40 - 12,200 miles
Sample#4 - May 2013 = Amsoil AMO 10w40 - 14,000 miles
Sample#5 - Mar 2014 = Amsoil AMO 10w40 - 15,000 miles
Sample#6 - Nov 2014 = Amsoil ACD 10w30 - 14,200 miles
Sample#7 - Jul 2015 = SuperTech Syn 5w30 - 10,100 miles
Sample#8 - Apr 2016 = Mobil1 5w30 - 11,000 miles
Sample#9 - Aug 2017 = Mobil1 5w30 - 13,000 miles
Sample#10 - Oct 2018 = Mobil1 5w30 - 14,500 miles
Sample#11 - Sep 2019 = Delvac1 ESP 5w40 - 11,000 miles
Sample#12 - Oct 2020 = Delvac1 ESP 5w30 - 11,100 miles
Sample#13 - Jan 2022 = Delvac1 ESP 5w30 - 10,000 miles
Sample#14 - Mar 2023 = Mobil1 5w20 - 6900 miles
Sample#15 – Sept 2024 = SuperTech 10k 5w30 & VPB”Restore” 10w30 – 6000 miles
@fantastic
Thanks for that detailed sample information. That would help to reason why Si is a bit higher. It has been consistent & wear trends are just fine. Also, do you know why the sample 1 had such a high Sodium spike? Always liked these FJ's & happy to see one not afraid of using the Boss. :cool:
@fantastic
Sodium, my guess is: like a dummy I listened to the wrong person and did some sort of engine flush? before switching to synthetic oil.
IMO the bypass filter system is the secret to my success with this vehicle. Without it I bet the Si might have done some damage.
@fantastic
We've all made that mistake of listening to "that guy". 😆
Agree, bypass filters are excellent if you can afford the installation & are going extended mileages.
Nice reports!
Why run R&P if it's not burning/using oil?
Your choice of "regular" fuel could be contributing to deteriorating atomization and fuel contamination.
I would try a fuel injector cleaner like Techron Concentrate AIO, Redline SI-1 or Royal Purple.
