Looking for a basic 12V compressor for household duty (inflatables and bike tires). What I would like is a 12V compressor that has clip leads that I can connect directly to the car battery instead of the cig lighter plug. The main reason for that is to avoid blowing the 10A car accessory fuse and most compressors that have atleast a reasonable psi and cfm capacity pull more than 10A at higher psi. This actually happened. I had a cheap $20 compressor that first blew the fuse and then when I pushed the compressor just a bit harder by putting a higher amp fuse, the compressor blew. And I see that on some good 12V compressors the amp rating goes above 10A for higher psi.
I could get around this by just replacing the cig lighter plug on the compressor with clip leads, or just get one that goes into the ac outlet (120V).
So any suggestions for compressors that come with clip leads, or go into an ac outlet ?
