Originally Posted by samven
That is a nice unit, I wish mine would go to 200 psi. I have a very old Craftsman 4 hp unit that pulls 18A at 240v, rated at 12.8 cfm @40 and 8.3@90 but it only goes to 125 psi and when I run the air hammer or needle scaler the compressor runs almost constantly because I have to have the reg set at 125 to get 90 at the end of the hose so as soon as I pull the trigger the pressure starts to drop until I hit the switch and it cycles back up and shuts off. With a higher pressure I could maintain my 125 reg setting.
This is what you need as I mentioned earlier:
https://smile.amazon.com/Milton-S-2...cm_cr_arp_d_product_top?ie=UTF8&th=1
Really makes a difference. Your pressure drop should not happen.
Also, use a 3/8" straight hose, not a cheap 1/4" curly hose.
Use the pressure and cfm recommended for the tool.
Most air tools are about 90 - 100 psi, but you may need more volume - cfm.
Anything rated over 150 psi is advertising hype. dave 123 got it right.
Also, whenever 220-240 volts is available, use it. Many motors may be easily switched. You already have it, this is for general info.
