Alan,
That is great that you searched for 1.8T UOAs. If you still have interest, look at ones that used LubroMoly, Pentosin, Amsoil, Valvoline (all 5W-40) and compare the iron ppm values to those from M1 0W-40 usage. Those are the oils that have shown such good iron wear number improvements.
Yeah, that claim of M10W-40 cleaning sludge/varnish is ** and is marketing. I have tested this very thing. Starting with a sludged/varnished metal cup, put virgin oil in and bring it up to 210F degrees or so for several hours, and see if the oil can remove any of the deposits. Result: no change whatsoever. Once those deposits are there, no oil can remove them (except MAYBE a mostly ester oil, but I have not tested this). A good oil can prevent them from forming in the first place though. And M1 0W-40 is not horrible in this regard but is definitely not leading the pack.
Buster, I think you referred to my commment of "lighter" basestocks. That was a bad term to use, I admit. I should have said "lower viscosity basestocks", but lighter is so much easier to type.
This oil gets it's 40 weight attribute from having lots of VI improvers. As someone said (maybe you?) and I'll add to it, this oil is great for gas mileage and cold startups relative to other 40 weight oils and it great for long OCIs compared to any oil, and GOOD ENOUGH at wear protection.
