Hi,
vino22 - welcome to BITOG from a fellow and long time Porsche owner
Buster - Porsche insists on mandatory use of a 0w-40 libricant in vino22's engine! They have many Approved & Listed 5w-40 oils too - more than 0w-40s but they WANT a 0w-40 in there!
Since about MY73 Porsche have had the following limit to normal oil consumption;
400miles/quart or 1.5litres/1000kms
Oh Pablo - you said this, how absolutely "Amsoil"!
"This whole thread so Dougie could get back at TS? Wow - good thread none the less.
Oh well - I still think IF Amsoil had a 0W-40 that thinned like like M1, Doug would be on it like stink on shat. Amsoil does have AFF but it's not really for cars Funny the double edged sword....
M1 0W-40 thins. see data in this thread And we sometimes anecdotally observe less iron wear with 5W-40's see thread with TS and others. This does NOT make M1 0W-40 a bad oil choice. It's just that there are better choices. No miracle choices, just better choices. And I would never use this oil in my super car"
Pablo - of course you will use the Amsoil products you sell - you have to love them!
And you have purposely avoided the point and reverted to the old Amsoil "knock Mobil" marketing ploy again but at least no 4 ball references yet. The thread was on 0w-40 Approved & Listed oils - NOT M1!
You said;
"M1 0W-40 thins"
Well so do many oils but the question remains Pablo, what does this really mean? Is it bad? Is it good? Does it really matter? I know it doesn't!!
And remember these words?
"I may have misspoken...it seems wear was reduced by 50%-70% compared to the Mobil 1, 0w-40, rather than the mere 25%-40% I had predicted in the previous thread. LOL!"
And these too;
"....excessive shear...." and "....excessive valve train wear...."
Where are the facts to support this "stuff" and what criteria supports "excessive"?
Many people on here have said that most Amsoil products become excessively thick with use. Frankly, what does this mean? Is it bad? Is it good? Does it really matter? I hope not!
But as most of Amsoil's products are not Approved and Listed they surely don't rate a mention on this thread now do they? Especially a "no car" 0w-40!
JAG - OT. I use EGTs taken off the pyrometer. We log these and the oil and coolant temperatures too in specific situations. We often reach 1000F EGT and often sustain it for long periods of 20-30 minutes or so - oil temps have never exceeded 112C - automatic power/shutdown @ max. 121C - and coolant has never exceeded 95C - automatic power/shutdown @ max.106C. Additionally, these are logged in the engine's ECM along with the engine's load factor
These turbos are not "cooled" and the oil return temperature is often in the 160-190C range. This is but one reason why I use an HDEO with a HTHS vis around 4cSt
When turbos first became "common" in the 1960s the cassette's replacement life was about 20-70kkms. This was mainly due to their poor design, metallurgy, location, oil formulation/pressure/flow and poor cooling considerations etc. Driver inexperience played a major role too. HD oils and especially CAT Series 3 oils minimised turbo failures and extended their life in petrol engine applications at that time
Today's turbo-chargers do not need to be idled down for more that about a minute and many car applications are coolant cooled. We use the pyrometer's green band
Back to the 0w-40 versus 5-40 issue we should not forget that we are dealing with SAE40 oils - not 0w/5w lubricants - and with an HTHS viscosity of around 3.5cSt.
ebaker - your comments;
"The research engineers have to deal with many compromises, notably in the area of emissions and the extended emissions system warrantys required in the US. I worry about the compromises needed to make M1 0w40 pass SM standards. The elemental analyses of SM M1 oils look much less robust than the SL oils."
I tend to agree and again one should surely refer to the engine Manufacturer's Approval's Lists to see whether any perceived quality downgrade has resulted in the product being de-listed. I like the characteristics of Delvac 1 as a CH-4 rather than a CI-4+ but the durability aspects are identical in use - often some fears are proven to be groundless
And finally a question for those with doubts - if you were a producer of some of the most advanced and powerful - kW/ltr - engines ever made using twin turbos and advanved valve actuation etc, gave them three years unlimited distance warranty in the hands of "the public" and insisted that the OCI was annual or 20kkms, would you use and insist on service filling with a substandard lubricant? The answer would surely be NO!
That is why Porsche only endorse using an Approved & Listed 0w-40 lubricant in the Cayenne and why it is their factory fill!!
It just happens to be M1 0w-40 at the factory?
I am so pleased you have enjoyed this thread Pablo!
Doug
[ October 25, 2005, 07:41 PM: Message edited by: Doug Hillary ]
