2007 Odyssey, 168K. This is the J35A7 engine with VCM. Second owner. Oil changes have been done per the OLM with conventional. The engine consumes a lot of oil and does not get topped off.
Vehicle was experiencing misfires under load. Had a P0300 and various cylinder specific misfires. Also heard a light tick. Removed both valve covers and found exhaust valve clearance to be almost zilch, intakes were in spec. Front camshaft had pitting/scoring on the #4 and #5 lobes. Was not able to inspect the rear camshaft due to the design of the rocker arms. #1 and #3 plugs were worn and ashy, others were fine.
Temporary fix for now was to adjust the valve clearance and install new spark plugs. Misfire issue has been resolved for now but it will need a new cam.
