There are a lot of small screens in these engines, it does not take much to clog one or more and cause oil starvation issues especially to the head and balance shafts. IIRC there are 8 screens in the balance shafts (4ea) 1 in the vacuum pump, 1 in the oil pump, depending on the engine code 2 in the VVT system and possible a few others I cant think of at the moment.
Scoring of the cam is usually due to oil starvation. When I do these I usually yank the engine, it makes life so much easier, pull the chains and guides etc, pull the pump and check the screen. Replace the rear main seal with a billet framed one, if you find RTV debris replace the balance shafts and sprocket with new screens. Whatever you do or don't do change the oil every 3-4K and use spec synthetic oil.
