03 Honda CR-V loses oil like crazy!
Is it safe to use 5w40 in a 2.4L Honda CR-V engine? That sounds kinda thick considering it was originally using 5w20.
Also, like the AKhan87 asked, why didn't you use Valvoline Restore & Protect 5w30? You probably have a reason. I'm just curious.
The 5w40 works well and I’ve been using it for, I’m guessing, about 80k now. It might lower mpg slightly but I’ve never measured that and haven’t noticed any other difference. Maybe I should try 20w50 🤓🤓
As for R&P, I’ve been using the 5w40 for much longer than R&P has been available and at 2 litres of usage per OCI, it’s not something I’m concerned about.
Now that it’s available in Canada I might try it sometime but I no longer have an issue that I feel needs any attention.
20w50? Oh lordy! 😳
How many miles is your OCI?
I think you're masking the issue, but maybe that's good enough.
that's a metal PCV Valve, it can be cleaned (as long as it is OEM), doesn't need to be replaced.
I would personally remove that intake and clean it as well, along with the Throttle Body but it all depends on your skillset.
I agree that metal PCV can be cleaned. Maybe plastic PCV can also be cleaned?
For convenience I bought a new $15 PCV from Oreilly. It's a Microgard, which probably means made by Premium Guard. Is that OK or should I have bought an OEM Genuine Honda PCV? Does brand of PCV matter? It says it's made for Gen 2 CR-V (and this is a Gen 2, 2003 CR-V).
For the crankcase breather hose, does it need to be OEM Genuine Honda or is aftermarket from NAPA or Oreilly OK?
I'm not considering paying for this, but I'm curious.
Do people sometimes rebuild Honda 2.4L using high quality, traditional rings that have more tension or spring pressure? It seems like that would fix the achilles heel of this engine.
I can rebuild that engine using EngineTech rings and they are the same type of rings as OEM, I have never ever had issues with EngineTech piston rings, connecting or main rod bearings, I would use them when available.
also the reason that Honda 2.4L is burning oil is neglect to begin with, people don't change oil in time or don't use high quality motor oils.
I know for a fact that this Honda was severely neglected. However, I'm equally sure that Glenda did not neglect her Subaru which had it's own oil consumption problem. So I think neglect is a contributing factor with modern engines, but not the entire issue.
I've seen Jeep 4L, Ford 300 straight 6, Chrysler 318, Chrysler Slant 6, Chevy 350, Mazda 1979 1.2L and others receive neglect and/or abuse and shrug it off. I've heard that older Toyotas and Hondas were also tough like that.
I think somethings have changed where many (or most?) modern engines can't shrug off any neglect or abuse, and many of them have problems even when well cared for.
It is an insulated and pre-molded Honda specific part: 17131-RAA-A00.
The $14 price in the image you uploaded looks like a good price to me, especially if it's an OEM Genuine Honda CR-V hose for PCV.
I want to order it. Rockauto does not have the OEM Genuine Honda part. Rockauto does have a Gates brand PCV hose for Honda CR-V that costs $11 plus shipping.
Would the Gates part be good enough or should I get OEM Genuine Honda part?
What website did you get the image from that you uploaded? Where is the best place to get a good price for an OEM Genuine Honda PCV hose? I need to have it within 7 days.
That looks like a good price to me. I want to order it ASAP. I can order it from Rockauto, but I am wondering, what website did you get that image from?
I got it from Honda Parts Now, but be aware that their vehicle fitment locator shows it for a 2003 Element, not CR-V (even though both vehicles use the identical K24 motor).
If you have a Prime account, I'd get it from Amazon instead for about the same price once you pay shipping from HPN.
Honda OEM PCV Hose from Amazon
or
Gates EMH293
or
Gates EMH293
I used to order OEM parts from Amazon for my LG front load washer. They might be legit LG parts. It's difficult to trust 3rd party sellers at Amazon and Amazon isn't ever (that I've seen) a 1st party seller of LG washer parts.
The last time I bought an OEM LG washer part from Amazon (16 months ago) they sent me the wrong part. Just slightly different. Probably an older version (defective recalled version) of the part I actually ordered. It might be a legit OEM part, but not the right part, or likely not the current one.
Last week my washer flooded my laundry room. My cousin disassembled the machine and disgnosed which part failed. It's the part I purchased from Amazon 16 months ago.
We compared the failed part to the new replacement part that just arrived from same Amazon seller. We compared the parts. They're not quite the same. That's when we questioned which part is the current and correct version. Further investigation online and at LG's parts website revealed that the failed version is the wrong part.
This is cost me hundreds of dollars in labor for flood cleanup and repairing washing machine a 2nd time. All over a failed part that I paid Amazon $18 for. LG sells the correct OEM part for $22 + $10 shipping.
My cousin and I share the blame along with Amazon because we wrongly assumed 16 months ago that I had received the part I ordered and we weren't paranoid enough.
I don't trust Amazon 2nd or 3rd party sellers. If Amazon itself is the seller, then I trust them. I now only buy LG washer parts direct from LG or Sears.
So now I'm also reluctant to buy car parts from Amazon, unless Amazon itself is the 1st party seller.
The Gates aftermarket PCV hose is sold and shipped by Amazon and sourced through the Gates Store on Amazon. I doubt it is counterfeit.
Gates EMH293
The link you provided would for sure be a legit Gates hose because Gates is the seller.
Also, for the OEM hose on Amazon link you provided... I now see that Bergstrom Honda dealership is the 2nd party seller. Obviously a Honda dealership is a trustworthy seller.
So my rant about Amazon doesn't apply to either of the Amazon links you provided because both of the ones you provided are trustyworthy. My bad. I'm feeling very financially and psychologically tramatized and beat down by the laundry room flood and washer repair disaster. It has made me justifiably paranoid about Amazon 2nd party sellers.
However, I now realize that some 2nd party sellers on Amazon are trustworthy and the ones you linked to are trustworthy. I apologize. Please pardon my earlier irrelevant, cranky old man rant about Amazon.
I appreciate your knowledge and helpfulness. 🙏👍
By the way you describe the neglected CR-V, I would just clean up the old PCV valve with carb cleaner and reinstall it with the old hose to see if it collapses under vacuum before buying a new hose.
Thanks. Good idea.
I already bought a new Oreilly Microgard PCV for it. It's still in the box and I still have the receipt. I assume a Microgard PC-V is acceptable?
