2010 CR-V oil use...
Got a 2010 Honda CR-V, 2.4 engine with 175k miles for my son in June.
Well maintained, overall.
Engine runs great, but has a mildly lumpy idle.
I did the usual stuff like new air filter, plugs, and PVC valve (just because).
All fluids were full and appeared in good condition.
I was stunned recently when my son said the oil light briefly popped on when taking a corner.
I told him to check the oil, and it wasn't even touching the dipstick.
Topped it off, and decided it must be an oil leak or possible sticky piston rings. I had cleaned the outside of the engine, so leaks should be easy to spot.
I got some UV dye and threw it in, and ordered some BG109.
Been a couple of weeks, no oil drips...oil level dropped just a bit, but the car hasn't been driven as much. I plan to get the car on stands and look with the UV light next weekend, but I'm not seeing any signs of leakage.
This morning I'm thinking about the issue because it seems new (the prior owner was meticulous and forthright regarding any issues and maintenance).
I know the PVC can cause oil consumption. I just replaced it, but figured maybe it is malfunctioning, so I pull it.
Nice rattle. There is some oil on the threads.
I run a wire through the oil passage, no blockage.
I reattach the vac hose and fire the car up: the valve seems to be sucked wide open at idle. Whiskey tango foxtrot?
(For reference, there isn't any notable blow-by at the oil cap or PVC inlet)
Ok... I'm thinking this might be the (or part of the) problem.
The new PCV valve is a Standard Motor Products from Rock Auto. The nice metal one, like OEM, for about $19.
Perhaps this one isn't the proper spec...?
I'm about to order an OEM valve for about $30 (ouch), and will be doing some piston soaks and a BG109 treatment probably next weekend.
What say the mighty BITOGgers? Am I on the right track?
I'm a former wrench, but pretty rusty. ;o)
Bob
Could give valvoline restore and protect 5w-30 a try. How many trans fluid changes has it had.
Thanks for the replies.
I also found a similar thread for a similar engine, but not exactly the same.
The guy was using something called HPC, I think, to try to free up rings.
My question is moreso about the possibility of the PCV causing the problem (never run into a PCB causing so much trouble, but I've not been in the field for over 25 years).
Anyway , I figure I'll do "all of the above," including OEM PCV (just to be sure), piston soak w/Berryman and the BG oil treatment.
I already purchased Valvoline full synthetic high mileage (initially thinking the loss was due to a leak).
I'll be changing the trans and diff fluid in the next few weeks.
Interestingly, the engine runs really well (the 2.4 K engine was a good one), but I think the mileage may be a little lacking.
Bob
The last years of the 2.4 were the ones that Honda used the "low tension" piston rings that are notorious for gumming up.
I've read something about the low tension rings, but wasn't sure which years were affected.
I be giving the rings a good cleaning...
Bob
When it looks open (the part you can see) the valve is actually closed/restricted, while under high vacuum at idke.
The open/closed restriction is located inside the valve, and you can't see it unless you dissect the valve. It functions sort of like a carb needle/seat assembly. Here's a post from a Fox Body forum that has a YT video with a cutaway demonstration, explains it pretty well. Hope this helps, friend!
https://www.corral.net/posts/18785716/
