03 Honda CR-V loses oil like crazy!
Sounds like a perfect candidate for some Valvoline Restore and Protect 5w30 🤔 (y)
It's a 2.4L. I assumed that's a 6 cyl, but I don't know. It might be a 4 cyl. Either way, it's an oil guzzler.
The CR-V has never had a 6 cylinder engine...always an inline 4. The 2003 CR-V has the venerable K24 series timing chain engine, which is among the best ever built by Honda.
I will ask my cousin to check that. However, there's not one drop of oil on the garage concrete floor where she parks. The concrete is pristinely clean. If there was an oil leak, wouldn't there be oil on the floor under her car?
This VTEC solenoid gasket is located high on the back of the engine. A copious amount of oil can leak down across the back of the block and get blown back across the lower control arm and undercarriage. It is possible for it not to show drops on the garage floor or driveway for a long time. I have personally replaced this gasket on various CR-Vs, Accords and Elements of the 1999-2006 vintage with the K24 motor.
Before doing anything else, I suggest inspecting the engine block area beneath the VTEC solenoid for a large oil leak. Honda K24 engines are notorious for gasket failures at this solenoid gasket as well as clogging of the integrated mesh screen. The VTEC solenoid (AKA: "spool valve") is located in the upper backside corner of the engine on the passenger side and it faces the firewall. On a 2003 CR-V, it is positioned ~6" above the oil filter. If it is leaking, only use the OEM Honda gasket and do not over torque it. Watch the video below for specifics.
The whole assembly can warp too. A new gasket won't fix the leak. I found that fun fact out. When replacing the PCV valve theres another small VTEC gasket in the front that often leaks.
I too, found this out the hard way after over torquing the VTEC solenoid assembly. The warpage is so subtle, you cannot detect it by placing the mating surface on a piece of glass/mirror. The leak was finally resolved after replacing the entire solenoid assembly when three new gasket replacements did not cure the leak.
I would post the Torque specs for the solenoid assembly, it will help OP if his car's solenoids are leaking.
OK. Here's a little more info. I'm severely handicapped. This car belong to my neighbor lady who helps take care of me. I do pay her for that, and she's also a caregiver for 2 other people. She works 3 part time jobs equal in hours to 1 full time job, but still has a hard time making ends meet. I want to help her with her car as a bonus to her and because she needs the help.
I'm not physically able to work on cars anymore. My cousin will do the easy stuff and I'll pay him and buy parts/supplies. Difficult tasks or tasks needing a lift or specialty tools I will pay my certified mechanic to do.
Essentially it's not my car, but I'm paying for the maintenance/repairs. I want to limit it to relatively cheap easy solutions.
I already bought a PCV. Next I'll buy a PCV hose. Those are cheap easy solutions that might help. Thanks for the hose advice.
As for checking the VTEC solenoid & gasket for leaks, that's a great idea. Hopefully replacing those won't cost to much money, if it's needed.
Valvoline Restore and Protect oil is another possible solution that I might also try, but I suspect if it's stuck rings they might be to far gone for Valvoline Restore and Protect to fix. My concern is that Valvoline Restore and Protect could get expensive with the CR-V needing an additional quart every 300-500 miles.
I have had 3 cars that burned oil and you would have never known. No smoke or anything. It is usually a PCV or something like that, but sometimes just poor mainenance causes scratching of the cylinder walls which lets oil get through.
If that is the case, there is not much you can do other than re-ring it or just keep putting more oil in. One of the cars was so bad that you had to put in a quart a month. But, it still ran perfectly fine.
You can have someone follow you and mash on the gas to see if there is a smoke or oil smell that they can see. As the driver it is hard to be aware of the rear exhaust.
Is the PCV hose a specific molded hose with a Honda part #, or is it just generic crankcase hose rolled off a spool at any auto store?
Valvoline Restore and Protect is pretty cheap from Walmart and has shown incredible results in certain engines, I would definitely try it.
instead of replacing those VTEC solenoids, I would get them cleaned first as that will cost a lot less.
Get the 5qt jugs at Walmart of the Valvoline Restore and Protect and refill some single qts from it. At least you'll be adding stuff that may help.
You could get some of the single qt bottles from the sale thread link https://bobistheoilguy.com/forums/threads/vrp-5w-20-single-quarts-at-amazon.397629/ with the added $5 rebate on 5qts that you submit on your phone. Do a couple separate 5 qt orders with the individuals. Keep the bottles and refill from the 5qt in the 5w30 afterward.
I mentioned possibly replacing because others mentioned possible warpage in the VTEC housing.
But first things first. PCV and crankcase ventilation hose will get replaced. Then I'll see if that helps. Then proceed from there.
The three 10 mm bolts for the VTEC solenoid assembly should only be torqued to 104 in-lb. (or ~9 ft.-lb.).
that is a very normal torque, I thought it was going to be around 50-65 in-lbs, why do people hulk things? just torque it to spec, even a common sense hand tight will get you in the 9 ft. lbs territory but I always use a torque wrench.
My 2005 CRV used quite a bit of oil initially. I found everything from 0w20 to 5w30 was about the same.
I bumped up to Supertech 5W40 Euro and it reduced usage significantly. You might want to try a thicker oil and see how it goes.
I replaced the PCV valve last year and it made a fairly small improvement. It now consistently uses a couple of litres (quarts) per 5000 mile OCi.
why not try Valvoline Restore and Protect 5w30?
Is it safe to use 5w40 in a 2.4L Honda CR-V engine? That sounds kinda thick considering it was originally using 5w20.
Also, like the AKhan87 asked, why didn't you use Valvoline Restore and Protect 5w30? You probably have a reason. I'm just curious.
Regarding replacing crankcase breather hose or PCV hose or whatever it's called... Is that hose a premolded (preshaped) hose with a specific Honda part # or is it just generic breather hose that autostores roll off a spool to sell by the foot?
