Been reading through a lot although much of what is discussed is over my head. I'm not cutting open my filters...yet.
2016 CR-V AWD with 120k. Had the head gasket changed a while back. Oil changes have been right around 8k based on the maintenance minder. Losing about 2.5 quarts in between the last couple of oil changes. Always used 0w-20 synthetic and OEM filters.
I think I will try Valvoline Restore and Protect for my next change. Should I also change to 30 weight? I'm in Virginia so we have cold and heat but the cold never gets too bad. And since I'm at higher mileage should my OCI change?
Thanks!!
Thanks!!
