I'm helping a friend of mine with an '02 Avalanche (5.3L USDM model) that is about to hit the 100,000 mile mark. So far this is what I've got on my list, with my choice of product in brackets:
- Engine oil and filter (Fuchs Titan SuperSyn LongLife 5w30 and ACDelco PF46)
- Air filter (AC A1518C)
- Fuel filter (AC GF652)
- Cabin air filter (CF104)
- A/T filter kit and gasket (GM 24208576)
- ATF cooler line flush (GM Vehicle Care Dexron VI)
- Front/rear differential fluid (CRC Sta-Lube 80W-90)
- Transfer case fluid (GM Vehicle Care Auto-Trac II 12378396)
- Brake fluid (Prestone DOT 3)
- Power steering fluid (GM 89020661)
- Coolant flush (cannot find G-05, don't want Dexcool - Motorcraft Premium Gold?)
- PCV valve (AC CV948C)
- Spark plugs (AC 41-985)
- Thermostat (AC 12T84D)
- Radiator cap (AC 12R27)
- Radiator hoses (upper and lower)
- Oxygen sensors (AC 213-819 Pre and AC 213-819 Post)
- Fan belt (AC 6K923)
Also going to do a tire rotation. Any suggestions on the coolant? Anything you reckon is missing on the list? Thanks!
