This is the latest report from my Mazda CX-7 Turbo.
1- Wear continues to drop calculated at ppm/1k miles
2- Fuel dilute is half of last time, BUT, would I have got more fuel in the oil had I run this oil to 4400 miles again???
3- Copper in this engine seems to start out horrible and then begins to fall quickly. GM and Acura/Honda vehicles do the same. It seems Mazda has similar short block properties.
3- I did add STP oil additive (blue bottle) to increase Zinc a bit, but mainly to increase viscosity. Don't know if it helped.
4- The Direct Fuel Injection in this engine is most definitely having a major impact on oil life and integrity.
5- It seems to me a thick 30W or thin 40W would alleviate the fuel dilute.
6- Synthetic oil should keep its integrity longer in this environment.
7- Currently running 4qts of Chevron Delo 400 and 1 1/2 qts of Pennzoil dino 5W-20. The coming cold weather here in MO is of concern to me.
Questions, comments or otherwise flaming is welcomed!
Rick
Code:
Havoline dino Motorcraft Motorcraft
5W-30 5W-20 Blend 5W-20 Blend
STP add
Miles/oil: 1770 4404 1744
Miles/engn: 2280 9744 11498
Aluminum 3 3 2
Chromium 1 1 0
Iron 17 18 5
Copper 107 72 16
Lead 0 2 0
Tin 2 0 0
Molybdenum 374 44 30
Nickel 0 0 0
Manganese 2 0 0
Silver 0 0 0
Titanium 0 0 0
Potassium 0 1 0
Boron 49 105 119
Silicon 15 5 3
Sodium 0 3 2
Calcium 1618 1852 1673
Magnesium 41 8 6
Phosphorus 758 622 676
Zinc 903 768 827
Barium 2 7 1
Viscosity: 55.1 49.1 52.3
Flashpoint: 360 330 350
Fuel: Trace 2.0% 1.0%
Antifreeze: 0% 0% 0%
Water: 0% 0% 0%
Insolubles: 0.3 0.6% 0.4%
Rick
Code:
STP add
Aluminum 3 3 2
Chromium 1 1 0
Iron 17 18 5
Copper 107 72 16
Lead 0 2 0
Tin 2 0 0
Nickel 0 0 0
Manganese 2 0 0
Silver 0 0 0
Titanium 0 0 0
Potassium 0 1 0
Boron 49 105 119
Silicon 15 5 3
Sodium 0 3 2
Magnesium 41 8 6
Zinc 903 768 827
Barium 2 7 1
Water: 0% 0% 0%
