This is an analysis from VW's new turbocharged direct injection diesel, passenger car engine. This
vehicle used an oiled foam air filter and it also had a small, "Oilgard" by-pass filter. The addition
of the by-pass filter raised the sump capacity by 1/2 quart, from 4.7 qts to 5.2 qts. No oil was added
during this 10k run. Use is high speed (70-85 mph) highway driving for the most part - note the
number of total miles on this engine ....(The 0w-30 is not CH-4 rated, but does meet the VW 505 spec
for their diesel engines.)
miles on engine/111k
miles on oil/10k
Viscosity @ 100c/10.7 centistokes
oxidation < 1.0%
nitration/11.4%
TBN/12.8
Soot Fuel and water were fine
Fe/21
Cr/0
Pb/2
Cu/2
Sn/1
Al/9
Ni/2
Si/4
Additives
Boron/36
Mg/341
Ca/3144
P/1244
Zn/1541
TooSlick
miles on oil/10k
oxidation < 1.0%
nitration/11.4%
TBN/12.8
Fe/21
Cr/0
Pb/2
Cu/2
Sn/1
Al/9
Ni/2
Si/4
Additives
Boron/36
Mg/341
Ca/3144
P/1244
Zn/1541
TooSlick
