New version of Winamp released
by Jimmy9190. 10/23/18 11:07 PM
Need turbo help
by Dylan1303. 10/23/18 11:06 PM
Friction Modifier
by ant. 10/23/18 10:50 PM
Where does the rock auto discount code go?
by DONWATERS. 10/23/18 09:20 PM
Paul Bunyan Trail - Crow Wing extension - Day 2
by Number_35. 10/23/18 09:20 PM
Itasca State Park - bike loop - Day 4
by Number_35. 10/23/18 09:14 PM
Scan Gauge II X-Gauges
by StevieC. 10/23/18 09:08 PM
Paul Bunyan Trail - short and steep - Day 3
by Number_35. 10/23/18 08:58 PM
by Number_35. 10/23/18 08:47 PM
I put 15W40 in my L83 Ecotec
by Realtech214. 10/23/18 08:22 PM
Burning off fuel dilution?
by Spetz. 10/23/18 07:19 PM
Clear Headlight Cover Correction?
by legandrex. 10/23/18 07:02 PM
FEDERATED PG 2500F CUT OPEN
by 53' Stude. 10/23/18 06:53 PM
Found a video on 6F35 disassembly
by SirTanon. 10/23/18 06:10 PM
Outboard oil safe to use in lawn mower?
by Jack2468. 10/23/18 05:43 PM
My Latest Purchase: 95 Chevrolet K1500
by dogememe. 10/23/18 05:05 PM
shaguar_ex_type, WmMaroon, hogan646, hermie, avatar299
66282 Registered Users
55 registered members (bbhero, ant, anndel, beanoil, 9 invisible), 1,041 guests, and 34 spiders.
Topics292,449
Posts4,879,691
Members66,282
Most Online2,494
Oct 17th, 2018
Right stuff diff cover side, #2 case side? #4894317
10/11/18 09:57 PM
10/11/18 09:57 PM
Iowa
Mikek13 Offline OP
Mikek13  Offline OP
Iowa
I'm changing out the oil of a dana 60 and 80 on a 97 dodge ctd. I spent allot of time removing the old silicone from the differential cover and case and decided I don't want to do that next time and ordered a few paper gaskets to try a method Ive had good luck with so far. Iv used this method on other engine covers, but never a differential cover
I usually adhere the gasket to the cover side with the Right Stuff, then apply Permatex #2 non drying on the case side so that I can remove the cover easily and reuse the gasket. I install it quickly and snugged up maybe 10 lbs, and then torque it home 30-60 minutes later. Ive read removing parts the right stuff has been used on is even more difficult than RTV, so I definitely don't want to use it that way.
Has anyone used this method on a differential? I don't see why if wouldn't work, but just throwing this out there.
Thanks!
97 4x4 ctd 5 speed 3.54
I never make mistakes! I succeed in finding out what doesn't work.
Re: Right stuff diff cover side, #2 case side? [Re: Mikek13] #4894327
10/11/18 10:15 PM
10/11/18 10:15 PM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
I don't do the whole gasket+RTV thing.
I've used a plain paper gasket, nothing on either side. And lubelocker gaskets, both with success.
2005 Tahoe - 135k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Right stuff diff cover side, #2 case side? [Re: Mikek13] #4894332
10/11/18 10:23 PM
10/11/18 10:23 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Drill & tap the bottom of both differentials.....I would do 3/8" NPT. I don't like using gaskets on Dana's.
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
Re: Right stuff diff cover side, #2 case side? [Re: Mikek13] #4894491
10/12/18 08:32 AM
10/12/18 08:32 AM
Florida
hatt Offline
hatt  Offline
Florida
If you're going to be pulling the cover often get Lubelocker gaskets.
2013 F150 5.0, PUP 10W-30, Wix 57502
2010 Camry 2.5, GTX 5W-20, Fram Ultra XG9972
Re: Right stuff diff cover side, #2 case side? [Re: Mikek13] #4894534
10/12/18 09:20 AM
10/12/18 09:20 AM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
I've read on here before about people using "The Right Stuff" and always wondered how they made out when it came time to remove it? From my experience, the "Stuff" is super stuff and would be very hard to remove?
I used some on my snowmobile trailer lid where a small section of the lid broke away from the frame that was caused by the previous owner. The Right Stuff was recommended to me by my buddy and it worked excellent but it dried hard and permanent, imo.
Personally, I couldn't imagine trying to remove it from anything so I would definitely choose/pick something else for my diff covers.
It's been years since I did a diff cover but I believe I used Hylomar something or other the last time I did one. No idea what's out there now that is likely better, but using "The Right Stuff", imo, is overkill and unnecessary.
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum for all 3.
Re: Right stuff diff cover side, #2 case side? [Re: Mikek13] #4894557
10/12/18 09:49 AM
10/12/18 09:49 AM
Canada
nobb Offline
nobb  Offline
Canada
You should only be using the gasket, no RTV. I am also going to experiment with a paper gasket on my next diff service because I hate scraping the RTV. The annoying thing about paper gaskets in high temp applications (coolant or oil sealing surfaces) is that it hardens and also becomes a pain to scrape off. I am hoping that since diffs don't really get hot, that the paper should peel right off on the next service.
Re: Right stuff diff cover side, #2 case side? [Re: Mikek13] #4894585
10/12/18 10:16 AM
10/12/18 10:16 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
If I use a " sealer " + gasket , I tend to use the " sealer " on the removable part . That way I can get it out ( to remove the gasket & sealer ) where I can better work on it . I do not use " sealer " on the " non-removable " surface .
Wyr
God bless
Re: Right stuff diff cover side, #2 case side? [Re: irv] #4894657
10/12/18 12:00 PM
10/12/18 12:00 PM
VW Fanboy Island
maxdustington Online content
maxdustington  Online Content
VW Fanboy Island
I think right stuff is for applications that are leak prone, or see elevated temperatures like that recent thread regarding valve cover gaskets on a Mopar 440. People are going to start using it on everything to prevent comebacks if it is effective, the next person to wrench on that component be dammed. I didn't know about Hylomar until I read about it on this forum, but the right stuff is ubiquitous.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Right stuff diff cover side, #2 case side? [Re: Mikek13] #4894659
10/12/18 12:03 PM
10/12/18 12:03 PM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
My only foray into paper gaskets ended up with a very slow leak that drove me crazy. Lubelocker or RTV are my only choices.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: Right stuff diff cover side, #2 case side? [Re: Mikek13] #4895040
10/12/18 07:46 PM
10/12/18 07:46 PM
Iowa
Mikek13 Offline OP
Mikek13  Offline OP
Iowa
The truck came factory with rtv, but Ive had such good luck with the combo I mentioned, I'm using it again on the diffs. I installed a oil pan on a different cummins this way, and throughout the engine, and its never leaked a drop. New owner loves it..
Less the $20 for the gaskets and maybe $5 for the sealer and service will be a breeze, only having to wipe off the old #2 and applying new.
Not even concerned that it will hold the precious amsoil..
Maybe this post was more me saying.. "hey guys, try this.."
Re: Right stuff diff cover side, #2 case side? [Re: Mikek13] #4895380
10/13/18 10:02 AM
10/13/18 10:02 AM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
I've used the Right Stuff on diff covers and all kinds of other things before and never had a problem with taking things apart or getting the residue off. It's nothing a wire wheel can't take off.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Right stuff diff cover side, #2 case side? [Re: Mikek13] #4895492
10/13/18 01:16 PM
10/13/18 01:16 PM
southwest Mo.
wtd Offline
wtd  Offline
southwest Mo.
I used a Lubelocker gasket on my 14 Mustang GT when I switched diff covers and after almost 30,000 miles still no leaks.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: Right stuff diff cover side, #2 case side? [Re: Mikek13] #4895520
10/13/18 02:19 PM
10/13/18 02:19 PM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
Use the Permatex gear oil RTV. Works great, never had a leak. Papergaskets MAY give you an annoying leak overtime, only solution is to loose $45 worth of gear oil and reseal.
Re: Right stuff diff cover side, #2 case side? [Re: Mikek13] #4895600
10/13/18 04:50 PM
10/13/18 04:50 PM
socal
barkingspider Offline
socal
The only time used rtv was when I installed a chrome diff cover on my Silverado as the chrome ones have a reputation of leaking. Never leaked. I only use OEM or felpro gaskets, never any issues
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Right stuff diff cover side, #2 case side? [Re: Mikek13] #4895678
10/13/18 07:14 PM
10/13/18 07:14 PM
Iowa
Mikek13 Offline OP
Mikek13  Offline OP
Iowa
I drove the truck to work today and not a drop.. Looks like we all have our favorite ways to seal up the pumpkin.. But I'll swear by a good paper gasket, adhered to the cover with the right stuff and permatex #2 on the case side. A thin layer of both and install the part quickly.
