OK have a custom built 522 Big block Chevy. Twin Turbo intercooled. Oil temp measured in the oil pan. Water temp stays just above 100 degrees. Jet boat, but oil temp climbs to over 300 degrees during high power runs and never goes below 250 degrees. It has one of the largest oil coolers available. 12 qt oil pan, well designed with windage tray. Oil pressure stays OK.
I'm curious: What design features of the engine will effect oil temp? Assuming that plumbing, oil cooler size, oil quantity etc are correct.
Royal Purple oil being used.
The major concern is oil breaking down. The oil is cooled before entering the engine. Do not know what the temp of the oil is there. Temp is measured in the pan. Even though the temp of the oil going into the engine is probably acceptable, the really hign temp in the pan is the concern of oil breaking down due to temp.
One final note, the turbochargers drain directly into the pan. The turbo housings are water cooled.
