You can not drive a hybrid with a bad main battery. And when that battery goes bad it will set off an audio alarm that is sooooo loud that you will have to stop and get out of the car.
There are cheap repair places that will replace only the cell(s) that went bad for several hundred dollars and give you a six month or 12 month warranty on the battery. That leaves you with a battery pack that is mostly old cells and they will soon fail. The right way to fix a bad main battery pack is to replace the entire pack and that cost several thousands of dollars. Then you will be good to go for another 8 to 12 years. I do not know the exact price to put an entirely new battery pack in an 09 Camry hybrid. Check with a Toyota dealer and see how much it cost. I'm guessing around $4,000
That car is worth what ever a non-hybrid 09 Camry is worth minus the cost of a new main battery pack because the main battery is due to go bad soon.
