4L60E add filter/cooler/temp gauge
by dogememe
Yesterday at 11:37 PM
Watching Netflix on Vizio E470VL..
by daves66nova
Yesterday at 11:10 PM
Michelin tires wore out rapidly
by llmercll
Yesterday at 11:09 PM
Seafoam Rebate Starts Feb. 1
by John_K
Yesterday at 10:30 PM
2017 Sentra SR Turbo Oil Recommendation
by Braymur
Yesterday at 10:29 PM
Notchy steering and greasing Moog tie rods
by mclasser
Yesterday at 10:17 PM
Strength rating of stainless steel/galvanized bolt
by motor_oil_madman
Yesterday at 10:06 PM
Rush officially calls it quits
by Jimmy9190
Yesterday at 08:41 PM
Oil recommendation for 2003 Mazda B2300 (Ranger)
by ryan2022
Yesterday at 08:09 PM
Autozone Castrol ATF on sale 2 for $10 until 2/8
by slacktide_bitog
Yesterday at 08:04 PM
Mobil 1 Extended Performance oil filter in Canada
by Snagglefoot
Yesterday at 07:45 PM
dual auto oil filters for transmission
by Oldtom
Yesterday at 07:44 PM
Kitchen sink basket assembly recommendations?
by MONKEYMAN
Yesterday at 07:05 PM
Old Girlfriend
by KeithS_NW_Ohio
Yesterday at 06:52 PM
Bob Lutz rumblings
by MaximaGuy
Yesterday at 06:45 PM
Valvoline's "Anti-Glug" Technology
by Nickdfresh
Yesterday at 05:52 PM
WORRIED: CT scan Dangers
by SumpChump
Yesterday at 05:02 PM
07 Honda Fit Sport (L15A) Mobil 1 AFE 0W/20 15,062
by albertdi
Yesterday at 04:52 PM
Lubing your Ratchets?
by maverickfhs
Yesterday at 04:41 PM
Stuff floating in oil additive...
by 351mustang65
Yesterday at 04:40 PM
mnmax, jimkaniki, Poee, picture09, Kat
63995 Registered Users
26 registered (Black, Crispysea, bbhero, digitalSniperX1, 1998CamryCE, Deltona_Dave, 3 invisible), 820 Guests and 23 Spiders online.
63995 Members
65 Forums
277086 Topics
Page 1 of 2 1 2 >
#4540972 - 10/12/17 08:23 AM Have you ever used a motor flush? Which one?
ZZman Offline
Loc: Michigan
I have many times but it was a long time ago before I started using Syn oil in my vehicles.
I used Gunk Motor Flush.
2003 Mercury Grand Marquis. Castrol Edge High Mileage oil
2008 Sebring Hardtop convertible. PP High Mileage oil
2006 Kawasaki Vulcan 900 LT
#4540983 - 10/12/17 08:35 AM Re: Have you ever used a motor flush? Which one? [Re: ZZman]
skyactiv Offline
Loc: The Midwest
The old fashioned ones are nothing but kerosene. Brand doesn't matter.
Me: 13' VW GTI 3 door 6 speed manual
#4540998 - 10/12/17 08:49 AM Re: Have you ever used a motor flush? Which one? [Re: skyactiv]
ZZman Offline
Loc: Michigan
Have you ever used one?
#4541000 - 10/12/17 08:52 AM Re: Have you ever used a motor flush? Which one? [Re: ZZman]
kschachn Offline
Loc: Upper Midwest
What would that have to do with anything? Are they just kerosene?
1994 BMW 530i, 222K
1996 Honda Accord, 251K
1999 Toyota Sienna, 387K
2000 Toyota ECHO, 264K
#4541014 - 10/12/17 09:08 AM Re: Have you ever used a motor flush? Which one? [Re: ZZman]
IndyIan Offline
Loc: Ontario, Canada
My Focus had one done at 20k miles before I got it... I guess the previous owner went over a year before getting an oil change(she didn't drive very much) at jiffy lube and was talked into it! I also found ATF in the transmission so all Jiffy Lube was doing was costing her money and actually shortening the life of the car...
I never have or will use a motor flush myself.
07 Focus ZXW, 5spd manual, 190km VWB 5W30
06 CRV, 5 spd auto AWD, 298km M1 EP 5W30
#4541028 - 10/12/17 09:27 AM Re: Have you ever used a motor flush? Which one? [Re: ZZman]
LeakySeals Offline
Loc: Hudson, NH
I used Gunk as well back in the 90's. I didn't perform a teardown after, but the stick was jet black, and there was weird stuff in the pan. Not chunks, what looked like mud, sand, chocolate syrup. Then I tried it again. was much cleaner, oil consumption was cut in half. So IMO it works on poorly maintained engines.
06 Escalade 6.0L AWD 155k. M1 EP 5w30 Fram TG
03 Maxima 3.5L Unknown miles ST 10w30
#4541029 - 10/12/17 09:28 AM Re: Have you ever used a motor flush? Which one? [Re: IndyIan]
khittner Offline
Loc: Michigan
I've used both the Amsoil engine flush and Kreen (as a piston soak) in my '02 Toyota Camry's 2AZ-FE engine. The engine has 264K miles on it, and it began using a quart of oil every 900-1200 miles, depending on viscosity starting at about 230K. I originally thought that I simply have the sticking rings/too-small return holes problem that is fairly common to these engines, and perhaps I do, but neither of these products, used as directed, resulted in any obvious "de-gunking" of the engine (rings, lands, or anywhere else) and has made no noticeable impact on the oil consumption. Perhaps this lack of efficacy of the engine flush products should've been expected; the car has had a pretty steady diet of good full-synthetic oil for the past 8 years/150K miles. I've had a leak-down compression test done on the engine by my usual independent mechanics' shop, and the engine has compression in all cylinders within 5% of a new spec, so I'm thinking now that the oil is coming in through worn valve guides, rather than past stuck or worn piston rings.
Edited by khittner (10/12/17 09:32 AM)
#4541042 - 10/12/17 09:40 AM Re: Have you ever used a motor flush? Which one? [Re: khittner]
LeakySeals Offline
Loc: Hudson, NH
Originally Posted By: khittner
I've used both the Amsoil engine flush and Kreen (as a piston soak) in my '02 Toyota Camry's 2AZ-FE engine. The engine has 264K miles on it, and it began using a quart of oil every 900-1200 miles, depending on viscosity starting at about 230K. I originally thought that I simply have the sticking rings/too-small return holes problem that is fairly common to these engines, and perhaps I do, but neither of these products, used as directed, resulted in any obvious "de-gunking" of the engine (rings, lands, or anywhere else) and has made no noticeable impact on the oil consumption. I've had a leak-down compression test done on the engine by my usual independent mechanics' shop, and the engine has compression in all cylinders within 5% of a new spec, so I'm thinking now that the oil is coming in through the valve guides, rather than past stuck or worn piston rings.
I'm quite familiar with that year 2AZ-FE. My 02 Camry lasted to 354k burning oil. IMO its a little of both. Clogged piston oil return holes, leaking valve seals. Nothing will unclog those holes short of a teardown and a drill. So if its just clogged piston oil return holes, a thicker oil will help. If its valve seals, you will definitely benefit from a HM oil with conditioners/swellers. You will see blue smoke at startup after sitting overnight, or for a couple days. Have someone start your car so you can watch the tailpipe. Very important on these engines, change the coolant. often. Its directly related to oil related issues (hot spots frying oil) , and potentially fatal flaw where the head bolts could randomly separate from the aluminum block. Best luck with oil I had was M1 10w30. Great cleaner, did a fantastic job with the valve seals.
#4541091 - 10/12/17 11:04 AM Re: Have you ever used a motor flush? Which one? [Re: ZZman]
Nickdfresh Offline
Loc: Buffalo, NY
No. Heard to many horror stories of it causing more problems than it fixed...
#4541105 - 10/12/17 11:30 AM Re: Have you ever used a motor flush? Which one? [Re: ZZman]
skyactiv Offline
Loc: The Midwest
Yes, on an engine I rebuilt. The inside of the engine was very clean. I didn't know the service history of the car and don't know the effect it had.
#4541113 - 10/12/17 11:48 AM Re: Have you ever used a motor flush? Which one? [Re: ZZman]
i_hate_autofraud Offline
Loc: Canada
Instead of buying a brand name engine flush with kerosene in it and pay $10 a bottle,
I buy a bottle of kerosene for $3! I get 4 flushes out of it over 5 yrs!
I found out about this trick from a trucker pal o/o in the '80s who looked after his own
truck, if he can do it, I could too.
#4541155 - 10/12/17 12:47 PM Re: Have you ever used a motor flush? Which one? [Re: ZZman]
Merkava_4 Offline
Loc: Clovis, CA
My Dad ruined the engine in his Cadillac with a motor oil flush. He drove the car a little ways and then the engine seized up. Tow truck came and got the car and took it to a repair shop. The engine was pulled, disassembled and sent to the machine shop. He kept the car for another 20 years after that.
#4541190 - 10/12/17 01:27 PM Re: Have you ever used a motor flush? Which one? [Re: ZZman]
Superflan Offline
Loc: Reunion Island
Used the cheapest i could find when I « needed » it, when buying used vehicles and doing the first oil change myself.. Instructions were always like « pour the bottle in the engine oil fill when at operating temperature, then let idle 15 minutes. DO NOT DRIVE »
The greatest improvement was on a 2LT Toyota engine.
I even ran straight gasoil (after flushing oil) for less than 5 seconds in a push mower briggs and stratton classic 35 engine, 10 years ago. The engine still runs like new today, with high torque demand, seeing many decks pass by...
Yaris 1.0 195mkm 10W40 A3/B4 SL/CF
Wife's Koleos 2.0 dCi DPF eco-map 146mkm 5W30 C3
Varadero 125 89mkm MA
#4541266 - 10/12/17 02:44 PM Re: Have you ever used a motor flush? Which one? [Re: ZZman]
panthermike Offline
Loc: Phoenix, AZ
The only marketed flush I've used was lubegard flush. It seemed gentler from their description than others but did do some cleaning from what I could tell. I would use it again if I ever felt I needed it.
'16 Ram Sport 1500; Havoline/Biotech, Wix 21K
'10 Impala; PHM/ Biotech, MG 111K
'70 F100; Valvoline 15w40/Biotech, Motorcraft
#4541318 - 10/12/17 03:54 PM Re: Have you ever used a motor flush? Which one? [Re: ZZman]
JC1 Offline
Loc: Oshawa, Ontario Canada
I've used gunk before (over 8 years ago). I didn't see a
difference in performance on a v6 Toyota.
I agree that the kerosene method is cheaper and maybe even more effective.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Wix Filter
1997 Honda Civic CX 5w-30 PPPP/Mahle Filter
Page 1 of 2 1 2 >
