CEL went out yesterday. I read up on what the issue may be; pulled the EGR valve and it was fine (but cleaned it a bit with brake cleaner). The most likely part is the VSV, which is an absolute pain to get to. No idea why it is where it is; it's under the intake manifold . Wound up removing RF wheel, putting a 12mm and 6" extension onto it, and then pulling on the ratchet from the topside (as the bolt was surprisingly stuck in place, use a six point socket on this, I started rounding mine with a 12 point). I guess banging on it fixed it, but I'll probably order up one.
Picked up a set of RT43's yesterday, nearly new. Will likely get a set of 14" rims for it on Friday. If I find $100 snows I'll get those too. Only thing left is the timing belt. Maybe I'll try to do that before winter, along with changing the coolant from who-knows-what back to Toyota Red.
Gave in and bought the MVH-381BT stereo. About $100 once done--$78 for the radio, $10 for the harness, $17 for the cubbyhole. Expensive upgrade, but I guess inline with the expensive quickstruts.
Harder to install than it should have been; but not hard to do. Pioneer's wiring instructions suck. They gave pin numbers going from 1 to 21; but the connector only had 16 pins--and only 12 had wires. Scratched my head for 15 minutes, trying to compare notes, before I hit up google and "discovered" that "everyone" sticks to a common set of wire colors.
The next hard part was putting screws into the Pioneer. The cubbyhole kit wanted me to reuse the screws from the Toyota head unit; too bad they were fine pitch and took forever to cut into the metal. Of course whatever screws might have been with the radio got left home (was in a rush today, finished the job while at work at lunchtime) so that may be my fault. Worst part: I wanted the cubbyhole on top of the radio. That way I could rest my wrist on the shifter and work the radio, done that in all my vehicles over the years. Oh well, I'll get over it--and if not, radio came with a remote.
Didn't use the BT yet but wired up the microphone and paired my phone. Did listen to FM and mp3's on the drive in--and it was quite nice (radio left sitting on the seat). FM reception I think is better than the Toyota radio (a boon), I like the RDS, and of course the BT/mp3/USB/aux will all be great to use. Already quite happy with it. Only things I don't like are: no battery backup in the radio (minor but I've already had to program twice), and no single button seek (have to hold down to make it seek next strong station) (not huge but all my other stereos do that).
Got 31 or 32mpg on the last tank, so it seems to have settled into that for mpg. Not stellar but "good enough". Moved over my Garmin and it's the road warrior I wanted.
