http://www.oilspecifications.org/ford.php
Quote:
Ford WSS-M2C913-A
Engine oil, Initial and service fill, SAE 5W-30. This specification meets the ILSAC GF-2 and ACEA A1-98 and B1-98 and additional Ford requirements.
Ford WSS-M2C913-B
The Ford M2C913-B specification is released in Europe for initial fill engine oils used for lubrication of spark ignition engines using gasoline and for compression ignition engines using diesel fuels. The specification is also used to define engine oils for servicing Ford engines where applicable. The oil shall meet all the requirements of the ILSAC GF-2 and GF-3 specification, the ACEA A1-98 and B1-98 specification and additional Ford requirements.
Ford WSS-M2C913-C
Fully backwards compatible and is strongly recommended for all applications that currently require the specification Ford M2C913-B. The new engine oil provides various benefits to the customer such as improved fuel economy benefits and high robustness to biodiesel fuels.
Ford WSS-M2C913-D
Introduced in 2012, oils meeting this specification are recommended for all Ford diesel engines except Ford Ka TDCi models manufactured before 2009 and Ford Galaxy 1.9 TDi models manufactured between 2000 and 2006. A product meeting this specification is especially recommended for diesel engines where M2C913-B or M2C913-C oils were initially required. An oil meeting this specification must be used in Ford Transit vehicles manufactured from 2012 onward with Duratorq 2.2 engine. Oils meeting this specification can be used with extended oil change intervals and are also suitable to be used in engines running on biodiesel or high sulfur diesel.
Ford WSS-M2C917-A
Viscosity SAE 5W40 engine oil for pump injector diesel engines.
Ford WSS-M2C934-A
Extended drain engine oil for vehicles equipped with diesel particulate filter (DPF).
Ford WSS-M2C937-A
Special engine oil for Ford Focus RS. Viscosity should be SAE 0W-40.
Ford WSS-M2C948-B
Largely based on the ACEA C2 oil sequence this spec requires a low SAPS 5W20 oil and is primarily designed for the 1.0 liter, 3-cylinder EcoBoost engine. Contains in-house tests for fuel economy and piston deposit control. Oils meeting this spec must provide a 0.9% fuel economy improvement over regular 5W-20 oils.
Ford WSS-M2C950-A
Special engine oil for Ford Focus Diesel 2.0 manufatured from September 2014 and Ford Mondeo Diesel 2.0 manufactured from 2015. Viscosity should be SAE 0W-30.
