Originally Posted By: jeepman3071
Originally Posted By: tig1
But small engines don't need more zinc than SN oils have.
+1
+2
ZDDP hysteria is overblown. 99% of its reason for existence as an additive was flat-tappet cams with high contact pressures. It might help cylinder wall lubrication occasionally under near-abusive usage, but if it ever comes into play for bearings the engine has bigger problems to worry about....
+1
+2
