2015:
Realized the interstate is 7.5 years old in service. Had issues (no start) and when I took it back to the dealer to check it out, they said it was shot. After reading on BITOG about batteries, charging etc, I sent my Craftsman charger packing and got a new one (Pro-Logix PL2320) and she hasn't had an issue since....
Today:
so I was working on the truck today, only the hood was open (small bulb).
Then I drove 15 miles, half highway and half city, to the hardware store. Came home, worked on the truck again for 30 minutes and left the key in the ON position. No radio or lights on and just the fan on the lowest speed.
Went to start the truck and it wouldn't turn over.
Hooked up the pro logix charger and put on 20A (no start feature) and it said 14% and less than 12v (this was connected directly to the posts since my usual ground wasn't working).
I started it right up, moved her and then shut her down.
Reconnected with negative on proper ground.
said 84% and just over 12v and after ten minutes she's at 87% charging at 20a.
Is this thing shot????
can't believe it went dead so quickly.
thanks
Today:
thanks
