...that measures when an oil film breaks down and metal to metal contact occurs in an engine?
I hope this isn't a really stupid question but I've been reading some about bearing design and lubrication and to be honest, the math goes over my head. I understand RPM, viscosity and load along with bearing design are pretty much the variables that determine when an oil film will fail.
So I got to thinking (dangerous, right?
), why not instrument an engine to detect when metal to metal contact happens; low RPM/high load (lugging) or is it more likely at high RPM? How much happens at startup and how about shutdown? You could run different oils through it to compare performance. Since oil is an insulator, could you electrically isolate the crankshaft from the block and then detect by continuity when metal to metal contact occurs? Has something like that ever been done?
I guess I'm wondering how much operating margin we have in todays engines? I'd like to think the whole time my engine is running all the bearings are riding on a nice cushion of oil. But in reality, does metal to metal contact happen once in a blue moon or is it fairly frequent?
