To expand on the subject line, the Burb makes a rattle on cold starts and I am not exactly sure how long it has been doing so. It happens every time it is started, but it is pretty erratic as far as how long it lasts and usually rattles for a second, stops for a second or two, rattles, stops, etc. with no apparent pattern. I believe it stops once warmed up. I finally got around to crawling underneath to check it out and tracked it down to the transmission. When I put my hand against the transmission pan I can feel the rattle. The last pan drop and filter change was done just under two years and 20k miles ago by my regular shop. They used an ATP gasket and filter kit and Dex III fluid (not sure which brand). Could it be an issue with the filter? Something mechanical and the whole thing is about to grenade?
