Quote:
CLP
Pre-clean using above procedure with FrogLube Solvent™.
For best results, apply heat to area to be treated. Heat from a heat lamp, heat blower or ambient sunlight is more than sufficient.
Apply FrogLube and allow time to
absorb. (heat quickens the rate of absorption)
Scrub, agitate, and wipe off excess. Normal cleaning tools such as nylon brushes, patches, wipes and towels are sufficient.
Lubricate per manufacturers instruction. FrogLube will work dry or wet.
Note: In hot/dusty or extreme cold, follow manufacturers directions for use in extreme environmental conditions.
If storing, apply a light coat for long term protection.
http://froglube.com/froglube-product-info/froglube-directions/
There is NO reason to apply a heat lamp to a lubricant. None. And metal does not "absorb" oil like a sponge. Marketing bunk like this is why I won't use the product.
And their MSDS:
http://froglube.com/wp-content/uploads/2013/08/FrogLube-Slovent-2013-MSDS.pdf
Almost every thing is listed as "N/A". Specific gravity >1 suggests chlorinated paraffin which is NOT natural. All of the health effects on the MSDS are "N/A" and I find nothing on their site about "non-toxic".
Their site says that it is insoluble in water but their MSDS says "complete"?
