Does anyone know a good place, online, to look for oversize filters and compare specifications and measurements to factory?
By the way, 95 Mercury Sable wagon V6.
I think we're getting a little overkill here. FL-1A is plenty big for such a vehicle. I've changed the oil on Tauruses before and there's really not an extra 1.5", especially with engine rotation.quote:
Originally posted by TallPaul:
If it is the Ford 3.0 V6 the spec is FL400s. I just installed the FL1A on my wifes '92 Aerostar 3.0 and it is working fine. Measured the mating surface of my 300 I6 pickup (which takes FL1A) and the Aerostar. OD is the same ID is different with much smaller ID on the Aerostar 3.0 block. Since the FL1A gasket is slightly larger diameter, this is not an issue. Only Wix site has gasket diameters. Now, if you think the FL1A gets you more capacity at 3/8" greater diameter over the FL400S, try a FL299 which is the same diameter as FL1A but 1.5 inches longer! All my vehicles are running oversized filters.
quote:
Originally posted by n8wvi:
I think there may even be a better alternative to the FL-400. The FL-400 crosses to Purolator 20195. The 20195 an 25230 are the same size, but the 25230 has the by-pass valve on the threaded end (so if it opens, it can't blow crud from the dirty side of the filter into you motor). I'm currently using the 25230 on my Soob (I don't know the 'Ford' part number that the 25230 crosses back to)
Dave
