The owners manual asks for:
Use SAE 0W-40 Mobil 1 Synthetic Engine Oil that meets API categories CF or better and the requirements of DaimlerChrysler Material Standard MS-10725. If you cannot find SAE 0W-40, then SAE 5W-40 Mobil 1 Synthetic Engine Oil is acceptable. Any engine oil that does not meet the manufacturer's requirements should not be used."
Castrol Edge SPT 5w-40 meets the API CF but does not mention MS-10725. However this engine is an Italian made VM Motori. Castrol Edge SPT meets the Euro diesel spec of A3-B4 for turbo diesels. Do you think this oil is fine to use? Castrol Q&A says no because it does not meet the MS-10725 standard. I tend to think it never tested or got approved for this standard but that this oil would be fine for this Euro diesel.
In other countries where this diesel Jeep is still used they follow the Euro spec for selecting diesel oils.
Your thoughts?
Castrol Edge specs
Your thoughts?
Castrol Edge specs
