Originally Posted By: sir1900
Are you flying on Air Canada? If so,
http://aircanada.com/en/travelinfo/airport/baggage/security.html#-explosives-corrosives-liquids
Reading this section by itself one might think one could get away sneaking 2 quarts of oil in. However, opening up the tabs down a few sections it does mention oils under flammables (though they hardly are flammable under temps under 450 to 500f)
Quote:
Flammable liquids and solids:
Flammable liquids are not accepted in either carry-on or checked baggage. These include but are not limited to: gasoline, petroleum spirits, oil-based paint, lacquer, stains, shellac, oils, wood alcohol, lighter or heating fuels.
Oddly enough... they even have a section for ionizers! Don't fly with your air purifiers peeps!
Quote:
Air purifiers and ionizers
Air purifiers and ionizers are not accepted in either carry-on or checked baggage and must not be used on board the aircraft at any time.
