[img:left]
[/img]
First oil was Mobil 1 TDT 5W-40 (4000miles)
Next came Mobil 1 15W-50 (4000miles)
Current report is Valvoline Dino VR-1 20W-50 (only 2000miles)
Maybe Mobil 1 is not an "iron solvent" for me as iron was as high or higher on the VR-1. Could be the old engine is just going to show these high metals until it dies. There is no iron in the block or cylinder walls, no tranny gears in the crankase oil and I did look at the cams and bottom end during this OCI (silicone sealant? YES!) and see no wear inside. I wonder about the timing chain..and there are gears that drive the balancer, alternator and output shaft.
